2wd Cos Gearbox Options?
Im looking into options on a 2wd Cos gearbox. They appear to be going up in price on EBAY, etc so what other options are there? Im not looking at spending more than a £500 or I would just buy another 2wd box everytime.
Ive been told of a Jag gearbox being stronger and fitting with small mods? Anyone have any info on this? Which box to use out of which car, mods needed, etc?
Thanks for any help
Thanks for any help
R5Ford, what Im getting @ is I don't wanna buy 5 boxes @ £500 when you can get something like a Jog box for £100 each after you've modded the car first. Im looking for as cheap options as possible.
And, not everyone had £2500 to spend at one time, so buying 5 boxes over different periods @ £500 would be a more suitable option.
Thanks for the info so far
Anyone got contact details for Euan or AVA please? Will contact them and see what info they don't mind sharing
Happily retired
I found the solution to the 2wd Cossie gearbox/Diff problems way back in 1999, the Box & Diff have never been overhauled since that time & will im sure cope with anything I can throw at it.
Used a Tremec TKO600 box as used in the Mustang TypeR but fitted with .8 5th gear. My diff problems were solved with a Jag 10.5" power-loc with a 3.54 ratio as fitted to Diamler Limos.
Reyland do the box conversion.
Thanks LHD, very informative thread ![Grin](https://passionford.com/forum/images/smilies/icon_smile.gif)
Rod, what sort of cash is that tho?
Just to pont out. I know it sounds like this work is for me, but its for me Brother (JB Fletch). His looking for stronger box options, but don't wanna spend shit loads. And if I buy a Saph his spent all the cash working out the strongest options
Happily retired
MAD Carbon Cossie
Cheers for the post bruv,
Mine's stuck in 4th gear
repairable ??
Has anyone got Lee's number ?? His sounds like an ideal solution
As Chip said.
Has to be cheap as lost me job not so long ago
Cheers for the help peeps !!![Big Grin](https://passionford.com/forum/images/smilies/icon_biggrin.gif)
jb
![Red Faced](https://passionford.com/forum/images/smilies/icon_redface.gif)
jb
this may be way off, but can't the 2wd mt75 box be used, is it any stronger than a T5, don't know much about them, i know the prop would have to be modded, or get a T5 out of a mustang/camero/z28, ebay.com have loads of them, shipping shouldn't be difficult, i got a car shipper to ship in his container when i got a set of 18's shipped, cost me £80 plus duty/vat.
is it the box thats weak or the transfer box, has anyone tried the 2wd mt75.
so the other cheep option is the mustang t5, said to be a lot stronger, don't know if its true, but a built t5 from the states would be cheaper than a uk one i would guess.
ok, here is an uprated t5 in america http://cgi.ebay.com/ebaymotors/PROMO...=p4506.c0.m245 fully rebuilt to better than new, with the exchange rate as it is now its only just over £500, plus a bit of shipping and duty
i run the jag getrag 265 box euan used to run
the centre spline is identical to t5,you just have to make a plate up to adapt bellhousing,and custom make a prop from the 2 you have
you dont need to change clutch and you do loose speedo drive,jag take it from the axle
box is alot stronger imo
ive had it solid mounted and gearstick shortened too
im in the middle of fitting supra w58 box strong and cheap box the ausies use these box's on a load of v6 and v8's good strong box but you do have to mate the bell housing and spiggot bush/bearing using a supra clutch
heres a link to a chap thats done it to a ford v6 http://capriperana.forumup.co.za/abo...priperana.html
dojj
28
11-09-2015 10:00 PM
