whys my boost tailing off? what does every1 elses boost peak and hold at?
ive just fitted a new genuine -34 actuator to my car and its peaking at 1.5bar but then drops down to 1.1bar quite quickly.
what could be causing it?
theres no leaks, i had 2 but found them and fixed them.
what else could cause it?
its a T34.63 on a cossie.
Most cars drop off mate, they will peak at one figure and hold another which is usually lower than it peaks.
Mine peaks 1.9 bar and holds 1.5 bar, so its nothing unusual.
its on greys and a msd chip,
time to up the boost again and go for a long run to see what its like on the motorway where i can hold it for longer.
The port to the actuator is STD
I had to remove the restrictor in the port to atmosphere to get that boost.
What one controls the held pressure?
Also I made the actuator length about 6mm short of the wasregate
MAD Carbon Cossie
Stu, link the pipe from the compressor housing straight to the actuator & see what boost you get, should peak & hold roughly same pressure.
It's prob the jets in ya Amal valve, got a 1/8th drill bit ?
I'll find that pressure reg for ya in mornin & give Wayne a call, oh & you gotta be out tomorrow night, we got some races on, usual place
jb
Jb, I txt Wayne yesterday I don't need the reg any more m8, I fitted a new pump and it's fine now.
But I do need a 4x4 knock sensor?
I want a boost controller, it's just the usual, more bloody money.
What time tonight m8, will try to come down.
-31, but it did it before aswell, and struggled to get enough boost out of it.
thats y i changed to the -34.
its not caused by the 34, was just surprised it drops so much.
Passion for Fords!
the maps between the -31 and -34 are potentially different, and the required amal jets will also potentially be different.
you shouldnt just sling a -34 on and hope for the best, as an absulute minimum it will need a fuelling and det check
regardless of what everyone elses peaks and holds at, yours should only run what your software is spec`d to run,
what injector size does it run?
stu told me i should be running the -34 and i bought it from him.
its on greys
and im pretty sure the paperwork with the chip said it would peak 32psi and hold 28.
but i cant remember
its on greys
but i cant remember
gchristophi
31-08-2015 10:36 PM
