Engine loom
Engine loom
Hi!!! I'm planning soon to built a new engine loom and I was thinking if there would be a problem by using shielded wire to the TPS, Phase sensor, CPS and MAP. The added cost is not a problem...
TPS would probably be ok if you fitted a bypass cap as it's a simple variable voltage. MAP like-wise. CPS's, no! However, given that you'd have to buy shielded wire for the CPS's, it does no harm to do the TPS and MAP properly. CPC do a cheap single twisted pair with foil shield and drain wire, marketed as an audio cable.
Chris
Chris
big_Rad
15-09-2017 09:36 AM
muz
16-08-2015 12:57 PM
