cossie rear diff question
Old Aug 13, 2009 | 02:26 PM
jonesymk2's Avatar
jonesymk2
Default cossie rear diff question
there was a post up the other day that had a link to another site with all the diff options on sierras and mk3 granadas,i cant remember what one it was to try and find it,what i want to know is can i swap the drive shaft cups from an xr4x4 diff onto a 2wd diff so i can use the 2wd diff in the 4x4 beam with the 4wd rear shafts,also what do i need to do to the diff/beam to fit the 2wd diff
Old Aug 14, 2009 | 09:00 AM
jonesymk2's Avatar
jonesymk2
anybody
Old Aug 14, 2009 | 10:14 AM
SillyFezzaMk1's Avatar
SillyFezzaMk1
Rubber Rhino Crew
I dont knwo about mk3 granadas but I do know that you cannot use a 2wd diff with 4x4 shafts.
To use a 2wd diff in a 4x4 beam you need to chop off a mounting lug on the beam and re-weld it 1/2 inch over to accomodate the bigger width of the diff (7 inch versus 7 1/2). You also need to use 2wd shafts, these fit fine into the hubs and arms etc.... so basically to put a 2wd diff into a 4x4 beam you need diff and shafts & a grinder/weld set.
Dan
Old Aug 14, 2009 | 10:30 AM
lloydmotorsport's Avatar
lloydmotorsport
cosworth parts specialist
yes ,you can change the 2wd cups for the 4x4 ones,
just remove the back cover,and release the c clips holding them in.
Old Aug 14, 2009 | 10:43 AM
jonesymk2's Avatar
jonesymk2
cheers mate i thought thats what i had read but couldnt remember where i had seen it lol can the 2wd rear diff be used with the 4x4 front diff ok aswell,i think ive seen that it is possible to use the 2 together as the difference in the ratios is so little that it should be fine
Old Aug 14, 2009 | 02:17 PM
lloydmotorsport
yes it will work ok.
Old Aug 14, 2009 | 06:49 PM
jonesymk2's Avatar
jonesymk2
cheers for the help mate much appreciated
Old Aug 14, 2009 | 08:22 PM
SillyFezzaMk1
Rubber Rhino Crew
Appologies for my incorrect info, never knew you could put the 4x4 output flanges onto the 2wd diff....always learning new tricks
Dan
Oct 9, 2015 07:38 PM
Chas
Sep 21, 2015 08:57 PM
xr4x4rs
Aug 6, 2015 09:03 PM
Bosch
Aug 4, 2015 05:14 PM
