Shotblasting at home
I've got a fairly good compressor (50 litre tank, 3hp twin cylinder pump and lots of pressure - 12 bar I think).
In Halfords they have a little shotblasting gun and wonder if it is any good for cleaning calipers etc?
Would I need anything else? Sand obviously, but what about a blast cabinet, or would I get away with using a cardboard/wooden box?
my mate used an old wardrobe lol
but sealer all arround the joins and then perspex on top with 2 holes for your hand
he had a vacum cleaner attatched also so it sucked the stuff out lol
worked well
he used aluminium oxide i think
worked well
Glass bead for alloy
Alu oxide for other metals
Sand for glass
Just bought a shotblast cabinet with everything you need to get you going, including 20kg of glass bead, and 20kg of alu oxide £150 made by clarke, came from machine mart
Sand for glass
we use glass beads for all stainless steel cause it aint got a cutting edge
ali oxide is ok for all other metals but if you got a lot of shit build up
then use some chilled iron use grade go7 its not to rough or fine
nipper.1
Ford KUGA
12
30-05-2022 07:39 PM
PRO-LINE MOTORSPORT
28-09-2015 09:54 PM
