Does anyone know the difference between different types of steel?
im making some tie bars for the front of my mini, and ive been told (by a very reputable source) that 304 Stainless is the best to use, but i always understood stainless to have a low tensile strength
if you have seen a mini front suspension setup you will understand how much tension is on this bit, and how much damage will be done if it goes wrong
It is a good grade but not for that purpose.
Look at the UTS of the material
304 SS = 500MPa
T45 = 700-900MPa
For suspension components I would use T45
It does not need a heat treatment after welding either!
http://www.elmdonmetals.co.uk/
304 SS = 500MPa
T45 = 700-900MPa
304 is a corrosion resistant stainless, ideal for exhaust, header tanks, and industrial sinks.
Might be worth speaking to a roll cage or chassis place like caged for an off cut!
have a word with Taylors Steel, they do ALL sorts of "normal" and "exotic" steels, we use them at work (Aerospace ind) they're normally spot on guys.
http://www.kompass.co.uk/directory/c...d/83235780.htm
I am curious to know, who is the very reputable source who advised you that 304 Stainless would be the best option?
wowk
30-03-2021 07:49 PM
07-10-2015 12:56 PM
