Plumber help RE combi boiler
Right basically for as long as i can remember ever since we moved into our house whenever you turn the hot water on the radiators warm up too which means the taps sometimes can take a while to get hot. Always meant to ask what it was but never got round to it so here goes lol.
My cousin had a similar thing which reminded me to ask, he cant remember what the bloke had to change or fix but was some kinf of valve or something?!
If anyone has any ideas would be grateful!! If its an easy fix then will do it myself but if its deff a pro only job then obviously will have to call someone in!!
Cheers for any help
Cheers for any help
Divertor for defo on a Baxi, they wanted Ł200 to change mine so i took it out, cleaned it and put it back in , that was a year ago and its still working faultlessly. Really easy to replace/repair mate.
The original Rouge Trader
If its the divertor sticking, it will be the hw paddle sticking in the control assy, drain boiler, turn off mains water, remove diapragm housing complete and then remove control assy and clean the shaft.
Refit in the reverse, job done.
DONT FORGET TO TURN THE ELECTRIC OFF FIRST THOUGH.
i had same fault on my potterton boiler, it was the diaphram. its cheap and easy to replace. Suggest change the micro switch the diapham pushes while ur at it.
Right according the the insruction manual it has a DHW (direct hot water) and a CH (central heating) valve in, havnt taken the cover off yet to look but am i guessing right that it has both?! IF so which one would be at fault or is it work doing both?!
Also is it just a case of replacing the diaphragms or worth changing the micro switches as said?!
Christian and Beccy
53
22-01-2005 07:06 AM
Christian and Beccy
13
18-10-2004 04:53 PM
