Sooooooooooooo close!!
Old Aug 2, 2009 | 08:53 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
Default Sooooooooooooo close!!
the 3dr will now turn over, has spark but no fuel
the FPR has pissed fuel out everywhere but its a bit dark to see exactly where from, and im done for the day now!
i think its probably a wiring error....
arse
Old Aug 2, 2009 | 08:59 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
How long you been building the sierra now Dan ?
Mine is still broke
Steve
Old Aug 2, 2009 | 09:04 PM
costina's Avatar
costina
Live long and prosper!!
What reg u using dan? have a spare 4x4 cos 1 if you need it
Paul
Old Aug 2, 2009 | 09:09 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Good news its sparking at least mate, shows the ecu is seeing the crank sensor properly at least.
Old Aug 2, 2009 | 09:14 PM
costina's Avatar
costina
Chip i hear your doing the map on this one for a pizza
good man
Dan will have to let me know i will pop over and say hi
Paul
Old Aug 2, 2009 | 09:55 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
i think the fpr is an xs power job, and i imagine its leaking cos i didnt check how tight the fittings are as it was getting dark. same reasone it pissed oil out the turbo feed pipe as that wasnt tight either
i have since foud that on a cossie the phase sensor controls the fuel. and when you do away with that you use a cam sensor... now my cam sensor is not connected, as i copied the old wiring loom from my escort that i was running the s8 on, and that didnt seem to use it...
so i think i have found the issue!
Old Aug 2, 2009 | 09:56 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
chip, well it was sparking... if it was in time i do not know lol
ill have another look tomoz
Old Aug 2, 2009 | 09:58 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
steve, had the car 4 years, its been off the road 3 lol
Old Aug 2, 2009 | 09:59 PM
andy escos's Avatar
andy escos
come on fudgey chop chop fella
Old Aug 2, 2009 | 10:12 PM
Chip's Avatar
Chip
Just found out its on EDIS, so the ecu might not be seeing a crank signal after all.
Stick a timing light on it, if it stays at 10 degrees the EDIS is getting no signal from the ECU as thats the default setting
Old Aug 2, 2009 | 10:13 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
where do get timing lights from these days lol?
Old Aug 2, 2009 | 10:14 PM
Chip's Avatar
Chip
ANY motor factors, or halfords
Old Aug 2, 2009 | 10:16 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
ok cool, ill have a look!
the ecu was turning on the fuel pump tho, as it shut off after a few seconds
Old Aug 3, 2009 | 08:54 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
right, just had another look. with the ecu powered up there is 12.5v on all injectors.
and it had 1 bar of fuel pressure
so the ecu switches the ground to the injectors, but what triggers this?
its a phase sensor on a cossie, but this is a zetec lol, it has a cam sensor but this is not plugged in, as there is no plug for it.
but the zetec lobe is different to a cossie, as they use 2 points 90 degrees apart and the zetec only had 1.
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Marv888
Sep 26, 2015 03:44 PM
`spotty
Sep 25, 2015 11:41 PM
pabloXR
Sep 21, 2015 12:42 PM
