I have a misfire :( BMW people look :) Diagnosis Good or Bad??? Please See inside
Post Whore
My 325 E36 has started to miss fire and dont know what to check first.....
In the morning it is fine but once i get 5 minutes down the road it does it every now and then but after 10 minutes it does it all the time.
I have looked and it has coil packs so i am guessing i will need to look at them first....can i check which one is busted or do i have to change them all??? Assuming that it is them
All replies and ideas welcome
Post Whore
Just got it back from the local garage and the diagnosis is
he said 2 coils are fcuked lol.....he said not even worth looking at the plugs if that is the case...he wants Ł250 to replace them and supply them lol...is that good or bad?? also said i shouldnt drive it at all till fixed????
i wouldnt buy genuine BMW coil packs on a car as old as a e36 325i
buy pattern parts from somone like http://www.camberleyautofactors.com/...t/view/75/125/
then fit yourself - they are easy to fit
Ł250 seems alot even if genuine parts are used
Wouldnt bother with the plugs unless they are due changed service wise!
as for changing all the coils if they are made by bremi your advised to replace all of them if they are made by bosh or any other make replace the offending ones.
Reason being once one bremi coil goes the rest usually follow suit
