Lambda sensor, how far from turbo?
Old Jul 27, 2009 | 04:43 PM
Gav Diamond's Avatar
Gav Diamond
Default Lambda sensor, how far from turbo?
Done a search but couldn't find anything.
How far should a lambda sensor be from the turbo as heard if its too close the heat kills them.
Thanks in advance guys
Old Jul 27, 2009 | 05:34 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
well, ford fitted the green top cossie sensors IN the exhaust housing!
but for me, within 6 inches of the turbo is fine, on a cossie i fit them just before the neck on the front pipe
Old Jul 27, 2009 | 05:56 PM
Gav Diamond
Cheers mate, forgot to say for a cossie
Old Jul 27, 2009 | 06:02 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
I'd put it further away than that. It doesn't need to be as close as EGT, I put them 18" from the Turbo. The sensors will last longer and have no ill effect on AFR readings.
Old Jul 27, 2009 | 06:04 PM
JTECH James
Passion for Fords!
but that isnt really possible on a cossie due to the shape of the downpipe,
Old Jul 27, 2009 | 06:38 PM
col93saphcos's Avatar
col93saphcos
thats were i put mine also used a heat bung thing,maybe help take some heat away,as above my standard lambda is in turbo exhaust housing
Old Jul 27, 2009 | 10:36 PM
Christian and Beccy
#1 in Spelling Club
I don't know offhand how the Cossie downpipe goes, but mine is just before the exhaust goes round under the sump. They are also better to be in the upper portion of the pipe so that condensation etc cannot lay in the sensor.
Old Jul 27, 2009 | 10:38 PM
J1mbo's Avatar
J1mbo
B1mbo
around 6" from the turbo
Old Jul 28, 2009 | 05:49 AM
Gav Diamond
Cheers guys
manuel boeckx
13
Oct 3, 2015 02:29 PM
Matt Baxter
Sep 16, 2015 08:30 PM
Tim Wharton
Aug 30, 2015 05:46 PM
Dahl88
Aug 22, 2015 08:16 PM
muz
Aug 16, 2015 12:57 PM
