Mounting a 50" plasma on a plasterboard wall - She's up!!
Old 22-07-2009 | 12:54 PM
  #41
666's Avatar
666
yes that is my head
i had this with a 42inch plasma, i cuta sqear out the plaster board, then bolted 2x4 to the wall the plaster board back on and bolt braket to the 2x4, i used 20 8inch screws for each price of 2x4 (used 4 bits), it held my wieght befor i put telly up, still up now (and i have stood up in to it and aint moved, hert me thow lol)
Old 22-07-2009 | 01:31 PM
  #42
Lambchop's Avatar
Lambchop
PF Idiot Sniper
In my kitchen i used big butterfly bolts for hanging my 32" lcd. I use a bracket that has 18" ish extension from the wall so i can adjust the angle etc. THought it was all good until one day i walked past the tv and thought i heard mice behind the walls. Stopped and listened and spotted the plaster bulging. It was pulling itself out i had to grab the tv and shou on the wife to get tools to remove the tv from the bracket
Ended up mounting a piece of wood on top of the plaster and screwing the bracket to that. Looks crap but havent got round to finding a better solution yet
Old 22-07-2009 | 02:54 PM
  #43
dojj's Avatar
dojj
Resident Wrestling Legend
Originally Posted by cjwood555
I favour anchor fixing / rawlbolts. You still need to put ply/timber between the blockwork and plasterboard though as A) the bolts need to pull against something to expand; and B) tightening the bracket against a pre-expanded bolt will cave in the plasterboard.
Dojj - you do not need that many fixings! See http://www.constructionfixings.com/A...olt%20type.pdf
According to that datasheet, the maximum shear load on a single M6 shield anchor bolt in blockwork is 1.8kN = around 180kg! The only reason for using multiple bolts is to stop the thing moving.
Chris
not that i'm doubting you mate, the bracket is only held onto the telly by 2 big metal hools that were screwed in using 6 x 20mm x M6 bolts
but it's the thought of it being there for as long as it's going to be there and it will never ever fall out of the wall that gives everyone the reassurance and peice of mind that it's a job done once, but done properly
if there were loads of little screws holding it in place i'd be for ever worrying about it falling off the wall
Old 22-07-2009 | 08:05 PM
  #44
cjwood555's Avatar
cjwood555
Indeed - In practice I would normally put in between 4 and 8 M8 or M10 bolts, dependent on design of bracket. Obviously there's no point using M6 bolts in 10mm holes even if you only want to hold up 20kg!
Chris
Old 03-08-2009 | 04:06 PM
  #45
RichieST's Avatar
RichieST
Well its up on the wall, I bought a VESA mount from ebay, and it was a lot easier than I thought it was going to be!
I found the studs in the wall behind, and screwed into them. I hung off it for a while and its definately not going anywhere!
Here's the pics.
Just gotta make a new unit now for the accessories, but I'm pretty chuffed!
Rich
Old 03-08-2009 | 04:20 PM
  #46
Ginge !'s Avatar
Ginge !
just finding my feet
looks nice though NOW you have the same problem as the rest of us,,,,,,, where can you put the dvd/sky box due to the stupid fucking 1 metre lengths of cables
i had to buy longer cables and have them located on the side of the TV,,, IMO it looks shite to want another solution that can hide the dvd/playstation blah blah blah and keep the room simple and tidy with no wires hanging about
Old 03-08-2009 | 04:26 PM
  #47
RichieST's Avatar
RichieST
I know what you mean, I'm going to make a cabinet to bolt to the wall underneath the telly. The wiring will be run behind the wall so hopefully I wont see a single wire!
It isn't ideal as I would like them gone however that isn't possible!!
Old 03-08-2009 | 06:58 PM
  #48
dojj's Avatar
dojj
they put a 3 inch drain pipe behind the telly to un all the wires
then they plastered the plug so yuo can see that
i'll get some pics up later tonight
Old 03-08-2009 | 07:17 PM
  #49
RichieST's Avatar
RichieST
Luckily all my walls are plasterboard cavity walls so running wires are easy peasy
Old 03-08-2009 | 08:33 PM
  #50
DaveZS's Avatar
DaveZS
Better use my strong hand
Forgot all about this thread, better late than never eh.
Old 03-08-2009 | 08:35 PM
  #51
RichieST's Avatar
RichieST
Tidy job that mate
Old 03-08-2009 | 08:44 PM
  #52
DaveZS's Avatar
DaveZS
Originally Posted by Rich170
Tidy job that mate
Old 03-08-2009 | 08:47 PM
  #53
foreigneRS's Avatar
foreigneRS
Testing the future
DaveZS, where did you get that mount from please?
Old 03-08-2009 | 08:52 PM
  #54
Rhys's Avatar
Rhys
Wow Rich that bracket does not take many screws? Mine has about eight to hold it to the wall! Hope it is ok for you though. I should get a pic of mine up too.
Old 03-08-2009 | 09:04 PM
  #55
RichieST's Avatar
RichieST
I was dubious but I followed the instructions with the kit! It was 4 quite hefty screws that screw in with a 13mm spanner.
I hung off it for a while (i'm 100kg heavier than my telly) and it didn't budge at all!
Old 03-08-2009 | 09:22 PM
  #56
Stu.H's Avatar
Stu.H
Heres mine
covered the cables with some conduit, if they were buried in the wall, its sods law i would have to change or replace a cable
Old 03-08-2009 | 09:26 PM
  #57
DaveZS's Avatar
DaveZS
Got it when I got the tv, all I know is its a Vogel
http://www.vogels.com/web/Consumer.htm
Not cheap, but worth it. Tilts, extents, swivels etc
Old 03-08-2009 | 09:42 PM
  #58
Stu.H's Avatar
Stu.H
Had to use 8mm bolts with mine, and about 10 of em... cost about Ł60 from empire direct........
  #59
cjwood555's Avatar
cjwood555
I can get trade prices on vogel stuff if anyone wants one of the above....
Old 03-08-2009 | 09:59 PM
  #60
Rhys's Avatar
Rhys
LOL got a picture of you hanging of the wall now!
I was the same when my TV was on the wall i was scared to take my hands away just incase lol. Will try get my pics up of my phone but i have left the leads up my old dears.
Old 04-08-2009 | 12:23 AM
  #61
RickyLee53's Avatar
RickyLee53
I'm unsure on this.
The Tv's look a bit better on the wall, but all the stands look worse.
Old 04-08-2009 | 06:43 AM
  #62
foreigneRS's Avatar
foreigneRS
Testing the future
thanks for that Dave
i'll be looking at decorating the lounge later and want to do something with the tv, so if one of these figures in the plans i'll give you a shout
Old 04-08-2009 | 07:19 AM
  #63
DaveZS's Avatar
DaveZS
I might be after another one in a few months time, i'll give you a shout
Old 04-08-2009 | 08:46 AM
  #64
northernmonkey's Avatar
northernmonkey
I didn't do it!
Just for future reference for anyone, i had the same problem mounting to plasterboard dot and dab walls, i used these rigifix bolts available from here:
http://markgrantcables.co.uk/shop/in...ex&cPath=49_37
Basically, these have a plastic insert that goes into the wall after drilling, then a metal screw that goes into the plastic bit (screw in by allen key) then another screw that holds the bracket up by screwing into the allen bit that is already in the wall.
Not very good at explaining but believe me, use 6 of these and the bloody thing ain't moving!
Here's mine, all done and cables hidden: (excuse the mess!)
Old 04-08-2009 | 10:31 AM
  #65
RichieST's Avatar
RichieST
Does she mind?
Old 04-08-2009 | 04:43 PM
  #66
RichieST's Avatar
RichieST
Originally Posted by northernmonkey
Nice that, don't you get neck/eye ache? I had to move mine down a bit, it was only 6 inches or so higher than when it was on the stand, but it didnt half make my eyes ache!
Old 04-08-2009 | 05:37 PM
  #67
Brian's Avatar
Brian
I am after a electronic wall mount would you be able to get a price please mate if i find the one we wont
Brian
Old 04-08-2009 | 07:17 PM
  #68
dojj's Avatar
dojj
ok, so it's not finished by a long way, needs a coat of paint and tidying up but you get the picture
Old 04-08-2009 | 07:57 PM
  #69
Rob Virgo's Avatar
Rob Virgo
ip for ye,
if your sat cable comes into the attic put the sky box up there.
I did that and have eight feeds going to various rooms thru an rf amp.magic eye them at tv about the size of a half squash ball to operate.
rob v
Old 04-08-2009 | 08:01 PM
  #70
Rhys's Avatar
Rhys
Cool Doji but why not put the plug behind the TV? As the way u done it spoils a bit imo
Old 04-08-2009 | 08:07 PM
  #71
dojj's Avatar
dojj
the builder put it there and it was all done by the time i got home
i wanted him to run 2 pipes round the back as well but he only put in one, still, it's enough for the small ammount of wires i need and big enough to fit 2 3 pin plugs and 2 big scart cables through the hale as well as the optic for the sound and the hdmi for the telly which is all that's needed, but i wanted to run the power and signal cables seperatly just because i could do amd left the pulg down the bottom
unfortunatly, that plug is spured from the upstairs ring and seeing as there is no other plug anywhere near the vicinity and the cable would have meant uprooting the carpets upstairs and down the mrs said just use the safest amount of cable and put the plugs behind the telly
and that's wher it's worked out
all i'm going to do is put one of them surrounds around it to cover it up and it should all look great
Old 04-08-2009 | 10:56 PM
  #72
northernmonkey
I didn't do it!
Not at all mate. I have it on a tilting bracket so the top is angled downwards. I was a bit concerned about looking up when it went there, but she wanted to keep the fire (grrrr!)
Old 05-08-2009 | 08:35 PM
  #73
Paulo P's Avatar
Paulo P
Good thread I bought a 50" Panasonic plasma last week so I've been looking at different mounts so that I can mount it on the wall. The walls in my house aren't plasterboard so after reading this thread I'm thinking of getting this http://cgi.ebay.co.uk/ws/eBayISAPI.d...tchlink:top:en
That will do the job for a 50" with some rawl bolts won't it? I'm going to use trunking to hide the cables, it's the best solution I can think of
Rich where did you get the beware of the hamster sign? He looks just like my wife's hamster Dave
Old 05-08-2009 | 10:23 PM
  #74
RichieST's Avatar
RichieST
Lol he looks like Gareth, mine and mr mrs's hamster too It was from pets at home!
That link you have posted is for a tilt one, the one I've got is fixed, which imo is better because it mounts closer to the wall.
http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=320383292599
This is the one I've got, and its fine, really strong and comes with all the fixings you will need
Old 06-08-2009 | 12:02 AM
  #75
Paulo P's Avatar
Paulo P
No definitely a Dave
She said she had seen signs in there and she's now promised him one, hopefully she can get one the same lol.
That one is better to be honest, I didn't want one that moves. I guess you screw half of it to the wall, the other half to the TV and hang it from the bracket? My mate is calling his mate who is a builder to see if he can help mount it, we can do it but I couldn't guarantee it would be level lol Thanks for the link, I've saved it and that's what I'll get
Old 06-08-2009 | 08:19 PM
  #76
cjwood555's Avatar
cjwood555
Trunking is for sissys :P Hire a wall chaser, or get a grinder, cut two 1" deep channels and inch apart, stick the cables in, shove some one-coat or finishing plaster over the top and you'll have a much smarter looking install
Old 06-08-2009 | 09:06 PM
  #77
foreigneRS's Avatar
foreigneRS
Testing the future
are you suggesting plastering directly onto the cables laid in the channel you've chased out?
Old 06-08-2009 | 09:24 PM
  #78
RichieST's Avatar
RichieST
Lol - its my hamster thats called gareth
Here he is lol
Yes thats right, one bit attaches to the wall, one bit to the telly, then they just hook together and tighten a couple of screws down to make sure it isn't going to come off again.
Old 07-08-2009 | 09:16 AM
  #79
ballin's Avatar
ballin
You really weigh 100kg more than a plasma?
Old 07-08-2009 | 09:47 AM
  #80
RichieST's Avatar
RichieST
Almost, I've just weighed myself, thought i was 140kg but I'm 104 Its all muscle honest
