General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
the escort cosworth abs has fault diagnostics unlike the sapphs
get it read
if you post up your problem you'll probably find the pf clan will fix the fault
get it read
What software do you need to be able to read the fault and where is the diagnostics port for it?
The auto electrican said he cant get a wiring diagrame anywhere but he will sort it anyway. He said the pump isnt getting power at all tho.
the pump system has it's own power supply in fact it has 2 for safety, so the pump will work even if you stick the ecu in the toilet
Both of the power supplys arent working then lol.
Can ford still use the diagnostics for the escort cosworth? I know the only dealer here who had the old break out box for the sierra sent it back to dagenham a long time ago he said. He said best they could do for the sierra was one of those flashing led reader things
