How to change a cambelt....
Needs Beer Tokens.....
I am on a mission at the moment on the clio, i have brought a gearbox and clutch which me and my mate are sticking in on Tuesday but..... the car is also loosing water, its not got any puddles, no smeg etc, sooo im going for water pump on its way out (French build quality rules!)
So obviously i will change the cambelt at the same time but is the cambelt simple enough to change? i am mechanicly-ish minded, do u have to lock the pulleys up then ur away with just changing the belt? or is there a whole lot more too it and i should leave it to my mechanic mate?,
Cheers Adam
Cheers Adam
Cheers Adam
Cheers Adam
get a diagram from a renault site and see what you reckon
its not difficult, just take your time and dont rush
once you've done it; turn it over by hand to make sure everything is tip top
tbh if you arent sure you best get a mechanic to do it, ive had to repair jobs from diy mechanics were they have got it wrong, and when it goes wrong with a cambelt it can be quite expensive
Resident Wrestling Legend
just don't do it with the belt off mind
line up the marks, remove the belt
change the water pump
put the belt back on again
tension
turn the engine over several times with a socket to see if everything still lines up the way it should and hasn't moved
make sure you check that the tensions and pump are tight
job done
don't get the belt greasy or wet though
tension
job done
tension
job done
pretty easy to do; just need a methodical approach and your halfway there, not sure what the tensioner is like to do on them but do that at the same time
the sproket on the crank is half the size of the cam sprockets, due to the crank rotating twice for every rotation of the cam/s
so you need to find top dead centre, which is where the #1 piston is at the top of the stroke, but due to there being a dwell on the top of the stroke the timing marks allow you to align everything up correctly top and bottom
07-10-2015 12:56 PM
rsguy
44
29-09-2015 03:29 PM
