bl**dy cosworths
bl**dy cosworths
coming home from work this morning, going a bit mental(clear roads and very cold), i gets to about 5k in fifth, when i hear and feel my engine dump its boost pressure( big whoosh and a load of chatter), i am thinking a boost hose come off or the like as the car is still not missing a beat(albeit a lot slower) and i can see no smoke behind me! i pulls up to a roundabout and i cannot see for smoke,
gets home and has a quick look, head still on, no oil anywhere, i remove turbo for an inspection and behold i have only half the exhaust blades left and severe casing damage!!
bollox, right before xmas
Pugo
Pugo
Originally Posted by xr2i-carl
surely if the blades are gone, they went down into the engine? therfore score the bores and in need of rebuild?! AM i right?
good luck sortin it
carl
good luck sortin it
carl
The 60ft Launch King
Chris - sorry off topic a bit..had a close inspection of ya orange beast yesterday..Very smart buddy Dash looked nice n neat aswell Shame the door wasn't open as there was a HKS turbo timer in the packet sitting just inside the driver door Also one thing that puzzled me why was the boost gauge at a 90 degree angle...you would have to snap ya neck to see it properley
The boost gauge is at that angle so at 2.2bar, the needle can be pointing the correct way
did look a shonky old gauge though...looked like something you would measure your blood pressure with
I seem to remember you were after a T4 not so long ago
Guess you'll definately want that T4 now
might as well as you won't be needing it for 18 months!!!
How do the blades go into the engine then
the last one i saw let go on the compressor side, threw the blades out the side of the i/cooler
Pugo
Pugo [/quote]
THAT'S what I mean from what I can see the bits of the blades WOULD have to get into the i/cooler and out the other side then pass through the throttle body into the inlet manifold and THEN enter the engine etc!
onto yours now get another old smoker turbo to get u by for now(if you need to drive it asap)if NOT then wait for the one YOUR after m8
Pugo [/quote]
Ex Full Price gold member
never managed to source one, so it was an old shonky obne on the car!!!!
Martin
$hit............ooops...........do you want it back???? you can have half now and the rest when i have dug it out of my exhaust and swept up the a13
fancy lending me a dodgy turbo....Bl00DY CHEEK!!!!
pugo
pugo
Adam Graham
06-09-2015 06:04 AM
