what size is battery cable?
been trying to find some battery cable to wire up the 3dr.
now one place, a farm shop only has some very excessive sized cable that is very expensive.
other place i found that you can buy it per meter is maplins, but its almost £4 a metre.
now, looking on halfords website they sell sets of jump leads that i will cut up and use the cable from, for about £16 for a 10mm cable, or £20 for a 16mm cable?
whats needed?
batter is an odyssey 30 in the back of the car, need about 3m max cable.
cheers
whats needed?
cheers
I would suggest you consider at least 25mm^2.
have a look at this thread, and follow some of the links :
http://www.clubgti.com/forum/showthread.php?t=162521
i ran 4awg cable from my battery to starter and alternator,
and i used to get problems when hotstarting, it was like the battery was dead, not always, just sometimes
since changing to 0awg it doesnt happen anymore.
dont see why people ask advice, then ignore it
your car i guess
and you can only try
spikey, its the biggest i could find!
and one persons problem doesnt mean ill have the same lol
and while your here, how have you earthed your batt mate? i will run a strap from the batt to the shell, but have you also ran a cable to the engine/gearbox?
or is that just strapped to the shell too?
cheers mbud
cheers mbud
stu also didnt say what car it was, and it could have been that the starter was fucked lol!
saying that, my starter is very close to the down pipe, so will have to do something about that lol
im sure 4awg is 4awg, audio or not lol
this stuff does look like audio cable tho as the insulation is transparent. i asked for totally black and red, but they dont do it.
much gayness!
much gayness!
The best cable to use is 35mm if your running to the boot , because of voltage drop especially when starting a car. I use cable that we build control panels with which is called tri-rated cable , its like a cross between speaker cable which is multistranded and electrical (solid cores) . 35mm will have about 35/40 strands making it very flexible and which can take high amps/voltages . 35mm is rated to about 130/140 amps so is ideal for a car , for 300amps like posted earlier this would be 185mm which is about 1 inch thick so i would be very dubious if the cable could handle 300amps, give us a shout if you need any as ive got some left over from my old car
cheers paul
as for earthing , 1 from the battery to the shell , 1 to the inner wing from battery , then loop from that to to gearbox and engine
cheers paul
well, the 4awg is to run from behind the passenger seat to the master switch on the dash
from the master switch the std ford wiring is used to the starter, alternator, and power circuit of the car.
the car only has a lighting circuit, and the stack guages
07-10-2015 12:56 PM
muz
30-09-2015 08:29 AM
