Builders- knocking internal load baring walls down..
Right ho chaps....
http://img.photobucket.com/albums/v2...useoutline.jpg
Just got my first house, currently refurbing it and what not and would potentially like to knock some walls down.
On the pic the double red lines are potentially where I'd like to make an opening- say up to 2 metres or wide enough for an internal french door type arrangment.
The black line is the party wall.
Its a 2 bed semi, 1930's, 2 brick thick construction, both walls I want to knock holes in go straight though the house to ceiling of the first floor and form the boundary between kitchen and dining room and dining room and living room.
Reason for change- to many doors and the kitchen is tight and cramped.
I'm not looking to add value as the location of the house sells it and it will always be a 2 bed semi... just want to make it a bit more open plan and roomy down stairs.
So questions.
Do I need to tell building control?
How do I work out how big a lintel or RSJ I need to put in.
Where would I get the lintels/rsj's from?
As a builder- if you were quoting for this job- just to supply/ install the lintels/rsj how much would you charge?? ( I can knock the walls down and make good myself)
Thanks peeps...
Jake
PS- pics when I get 5 mins, its a bit hectic at the mo.
So questions.
Thanks peeps...
Jake
a 2.5 long rsj 4" wide by 7" deep would cost Roughly £60, if the i would charge £ 250 for the pair , just to knock out and install the beams.
Skip extra and making good and beams at your cost .
That gives you an idea
Chasing Radders
Jake
That has to be one of the FUCKING WORST diagrams i have ever seen....................
I have been in the house and still cant work out where the fuck you are trying to draw,pmsl
14000+ post superhero
how will that effect things if you come to sell the house and theres no record or certificate to prove the works been done to a safe standard?
See you in the week for the crash course in central heating installation.
Thanks for the replies guys.. it was just an idea.... looking at cost more than anything else.
The comment about when coming to sell the house- I just got it and had no certificates for the re wire or the windows that were installed... houses dont appear to be like cars.
But.. Noted!
i wouldnt think renewing existing would need certs but altering the structure of the building might. i know we needed a proper cert and inspection by building control to convert an attic into a 3rd floor bedroom .
You dont NEED certs for this kind of work, but its advisable as i say, when you come to sell it they surveyor might pick up on the change and want it checking!
you need to get in contact with a structual eningeer, he will work out the loads and sizes of the steels required, once this is done you need to contact your local council get through to building control and then chose a builder
if you dont go through building control when you come to sell the house it will come up that changes have been made
mk3ste
17-10-2021 10:09 AM
07-10-2015 12:56 PM
Mc5506
05-10-2015 09:57 PM
DavidK
27-09-2015 02:55 PM
2m, baring, builder, certificate, conect, installation, kitchen, kncoking, livingroom, load, loadbaringwalls, needed, nkock, order, rsj, sales, wall
