RS500 Damper Fitting
Old 01-07-2009, 12:53 PM
  #41
Turbosystems
Super Moderator
Turbosystems's Avatar
most probably doug if you actually drove it fast they would probably need checking every time you come on boost lol
it is advisable as a man to check your nuts regularly roflol
Old 01-07-2009, 02:22 PM
  #42
costina
Live long and prosper!!
costina's Avatar
Originally Posted by mechanic28
hi ya mate where did you get the polished damper mate??i presume they can fit on a T34??
I have got a baileys one i presume due to the fact it has not got any dampening effect this is why my bloody turbo bolts(turbo to manifold)undo over a period of time!
not mine m8 just a pic to show steve think rsnissan's car
Paul
Old 01-07-2009, 02:26 PM
  #43
costina
costina's Avatar
Originally Posted by Turbosystems
harmonic resonation is a characteristic of the yb with the 2wd manifold hence why the guru's at coswoth fitted a damper as standard
it has nothing to do with the turbo coming on boost but the resonation can seriously affect the turbo
Thanks Tony i was just putting 2 and 2 together as steve had issues with his turbo thats all
what dose the harmonics feel like when on boost ? would i be right in saying it feels rough
Paul
Old 01-07-2009, 02:32 PM
  #44
bud-weis
Football Cwazy
bud-weis's Avatar
Paul
I doubt you could feel anything at all?? im guessing the frequencies would be way too high to hear it too.
I have had turbo brackets crack when using a bailey damper before...i switched to standard 2wd and it was fine.
Old 01-07-2009, 02:35 PM
  #45
costina
costina's Avatar
In that case why would steve be changing his
Paul
Old 01-07-2009, 02:42 PM
  #46
mechanic28
mechanic28's Avatar
lmao at the driving fast its a collectors peice now so got to take it easy and i do take my nuts regular specially after a good scrub!!!
hmm me thinks i will get one of these 500 dampers still got my standard one somewhere but prefer the look of the 500 ones
As i am a lazy bastard where caan you get these from
Old 01-07-2009, 02:44 PM
  #47
Turbosystems
Super Moderator
bring the engine up to 3k revs car static and at normal operating temperature,
increase rpm by 100 rpm increments whilst watching your turbo upto 4k rpm ,you will soon find the harsh spot for your engine.
If you have no damper fitted or it is worn out or incorrectly set you will see the turbo jumping around
Old 01-07-2009, 03:00 PM
  #48
Turbosystems
Super Moderator
doug you can get them from me 95 +7.95 p+p
Old 01-07-2009, 03:05 PM
  #49
R5FORD
R5FORD's Avatar
did 4x4's have dampers? As i havnt got a damper on my turbo/engine. its got a 200 block but its for a 2wd car.
Old 01-07-2009, 03:30 PM
  #50
Turbosystems
Super Moderator
4x4's and escort cosworths had a different exhaust manifold so a damper wasn't required
Old 01-07-2009, 03:35 PM
  #51
boXXer
GASH!
boXXer's Avatar
my shitley damper resonates around 2750 with no load and a almost brand new turbo, so its nothing to do with a fucked turbo. Its because its rose jointed and they vibrate causing the noise. Mines just pissing me off now, so im ditching it in favour of the T4 damper. I also need to know how it fits, lol.
Old 01-07-2009, 03:36 PM
  #52
Turbosystems
Super Moderator
easy when you know how to fit them i charge 15 quid to build them up and fit them
Old 01-07-2009, 03:41 PM
  #53
R5FORD
R5FORD's Avatar
so id only need one if i was running a 2wd ex manifold.. im 99% sure im runing a 4x4 manifold
Old 01-07-2009, 03:42 PM
  #54
boXXer
GASH!
boXXer's Avatar
yeah i can imagine they are piss when you know how. We need some Schematic drawings ;p
you can come fit mine for £15 if you dont mind the drive, lol.
Old 01-07-2009, 03:44 PM
  #55
cossie4i+
TT T38 Power
cossie4i+'s Avatar
Bloody hell, thats inflation since last night
Steve
Old 01-07-2009, 03:53 PM
  #56
cossie4i+
TT T38 Power
cossie4i+'s Avatar
You would if using a 2wd one
Steve
Old 01-07-2009, 03:54 PM
  #57
RWD_cossie_wil
RWD_cossie_wil's Avatar
I always thought bailey type dampers did fuck all.... What do the dampers actually do then? As I had terrible trouble with studs falling out of the exhaust on my old T34 saff, I take it the spring is the important part, to take the harshness out of the vibrations?
Also, I take it bailey type "dampers" are actually useful for taking the weight of larger turbos to save manifolds cracking etc?
Old 01-07-2009, 04:35 PM
  #58
Turbosystems
Super Moderator
the dampers are friction dampers which reduce the harmonic resonation
the standard cast manifold can support the weight of any large turbo it's the tubular ones that can't and require support brackets and braces
harmonic resonation causes studs to fall out and or brake it also affects the turbo operation
Old 01-07-2009, 04:40 PM
  #59
J1mbo
B1mbo
J1mbo's Avatar
hows this ??
jim
Old 01-07-2009, 04:44 PM
  #60
cossie4i+
TT T38 Power
cossie4i+'s Avatar
Spot on Jimbo
Thanks mate
Steve
Old 01-07-2009, 04:48 PM
  #61
J1mbo
B1mbo
J1mbo's Avatar
no bother mate
Old 01-07-2009, 05:00 PM
  #62
Turbosystems
Super Moderator
jim you want to be realigning that one it isn't on properly
Old 01-07-2009, 05:05 PM
  #63
J1mbo
B1mbo
J1mbo's Avatar
that would be down to me, it was off the engine so i put it back on for photos, but tbh i dont know how to allign them correctly or even that you had to !, ill leave that to the old chap lol
Old 01-07-2009, 05:08 PM
  #64
Turbosystems
Super Moderator
you can't get the staff these days Jimbo lol
looks like you have put it on how it was jimbo judging by the pad wear
Old 01-07-2009, 05:33 PM
  #65
J1mbo
B1mbo
J1mbo's Avatar
lol
when i took it off i put the clamp back over it to hold it all together as is so more than likely have, see im not all bad
Old 01-07-2009, 05:34 PM
  #66
RWD_cossie_wil
Great topic.
Tony, what is the actual problem then? I am trying to imagine what the damper actually does? I take it the vibrations/harmonics try to twist the manifold/turbo, or is it just pure frequency vibrations etc that the damper trys to eliminate/ move out of range?
I take it the natural frequency of a 2wd manifold is the cause of the problems? How do different size turbos affect this?
Old 01-07-2009, 09:19 PM
  #67
boXXer
GASH!
boXXer's Avatar
Excellent pics Jimbo
So how do you set them up correctly?
Old 01-07-2009, 09:21 PM
  #68
J1mbo
B1mbo
J1mbo's Avatar
if rainbird saw that he would faint ! im renowened for blurry pics
i am still wondering this too
Old 02-07-2009, 10:18 AM
  #69
RS500/364
RS500/364's Avatar
I would say that is more than likly the cause of my turbo faults NO DAMPER and 4 turbos
The bit that spaces to help fit !!
Matt Baxter
16-09-2015 08:30 PM
TrevCos
Modellers Corner.
24-08-2015 09:31 PM
A.t.p
15-08-2015 11:37 AM
TIL13R
11
13-08-2015 02:28 PM
Harris.
12
12-08-2015 06:38 AM
Quick Reply: RS500 Damper Fitting
