lacquer not drying clear?
![Question](https://passionford.com/forum/images/icons/icon5.gif)
hi,been painting couple bits,now when ive put lacquer on it looks shit,kind of white tint to lacquer,whats wrong?and how can i sort it?it is clear lacquer,not looking like car will be back on road tonight now,thanks
midges got the better of me!have given it a wet and dry and a good go over with cutting compound,hard to say how much better,bit dark now,if no use will rub it back and start again,but will heat tins up next time,bugger now is no one local has that fancy red paint,seems that dodgy tin was there last
lol,well stupidly i realise now ive a hot air gun thing in the car,doh,am doing it outside and it did get damp and shitty as normal,lol
will i have to take it right back to the primer if its not right?
i assume it would be worth heating area up with air gun thing before spraying,ok to use it to dry the paint/laquer?
thanks for the info guys,i'll try get it done properly tomorrow
Back in black!
I would use a hair dryer if it was me as the gun might be to much
you should get away with a quick flat off with a scotch pad, clean it off then a quick warm up on the wing I would also have the cans in some hot water ready to go you could then use the hair dryer to keep a LITTLE bit of heat in the wing
HTH
Matt
HTH
Matt
07-10-2015 12:56 PM
PRO-LINE MOTORSPORT
28-09-2015 09:54 PM
