Any house alarm Engineers about
Right where do I start!
At the moment I have the alarm running from a plug in 12v transformer which I have wired to the backup battery terminals because something happened to the internal AC transformer side of things, NOT a good thing to do I know because it will piss of the neighbours when theres a power-cut etc (BOTHERED)![Big Grin](https://passionford.com/forum/images/smilies/icon_biggrin.gif)
but now I need to turn off the Ring Circuit to do some other work so what I need to know is, is there a way I can isolate the external bell box via the engineers code or using a link wire between the terminals in the panel to stop the self powered bell box ringing.
The bell box looks for a constant 12V 'hold off' supply or it will sound.
Your battery should supply this when the power is cut, so put one in! I have a stack of old panels here I can probably sort a transformer for you if that's what you need? PM me a pic dude. Where are you?
As above you should have a battery backup which powers the alarm in power cut situations. If you haven't you'll probably have to get up to the bellbox and disconnect the battery to stop it ringing.....there are some systems that allow you to disconnect the bellbox remotely from the keypad when you put the alarm in engineers mode but not all will have this function.
OK sorry guys for the late reply but can you still help me.
I have now acquired a couple or spare new panels which I want to use to replace the old one which still works but it is running from an external 12v mains power adapter which is connected to the Battery + & - terminals, I done this when the internal transformer packed up thinking that I could just leave the Battery back up in place (connected to the BAT +/- terminals) and then connect the plug in 12v mans adapter into the AC terminals but this did not work for some reason, so I'm presuming that there's a fault in the AC circuit somewhere, I know it's not the fuses because that was the first thing that I tried.
Anyway what I need to know is:
Question 1: which one of these should I use? the on with the extra resistors and coil on the back are from the Accord model (which is what mine is called) and the other one looks identical but without the extra resistors/coil, and is called an Intellisense ST900 but I think both are made by Ademco Microtech.
![](http://i13.photobucket.com/albums/a266/tosh-/100_1044.jpg)
![](http://i13.photobucket.com/albums/a266/tosh-/100_1039.jpg)
Question 2: I am going to change them over wire for wire which should be fool proof "I HOPE" but rather then trying to re-program the system I was thinking would it work if I just took the Chip out of mine and put it in the new circuit board, as it looks like they are removable like our ECU Chip's.
![](http://i13.photobucket.com/albums/a266/tosh-/INTELLISENSE2.jpg)
![](http://i13.photobucket.com/albums/a266/tosh-/ACCORD2.jpg)
Question 3: do you think that the Chip in the ubove photos would be the on that holds the programing dater.
Question 4: Has any of this made any sense.
Question 5: Are you all still awake or have I bored you all to tears.
Question 6: Am I an idiot "DON'T ANSWER THIS ONE BECAUSE I HAVE FEELINGS"
Thanks in advance, I know it's all a bit complex and long winded but any help will be much appreciated.
Here is a few more pics to help you experts identify the alarm that i'm on about.
![](http://i13.photobucket.com/albums/a266/tosh-/ACCORD3.jpg)
![](http://i13.photobucket.com/albums/a266/tosh-/INTELLISENSEKEYPAD.jpg)
![](http://i13.photobucket.com/albums/a266/tosh-/ACCORD1.jpg)
kosienutter
31
22-08-2015 09:55 AM
