aaarrrrggghhhh crap ( all fixed now)A WARNING TO YOU ALL BE AWARE
Old 20-06-2009, 11:46 PM
  #41
Fudgey
Baby Cheesus
Fudgey's Avatar
Originally Posted by RWD_cossie_wil
I don't understand the failure mechanism there? ... The bolts are under no load, as the vertical load is being transmitted through the two large plates/stepped washers either side of the TCA, via the stepped hole in the TCA. The horizontal /car moving forwards directional loading is pushing the compression strut into the car, so the bolt is under no real axial load!! The only time I can see the bolts being directly stressed is if the car is going backwards, where the bolt will be holding the strut together against the front washer/plate in the TCA.
Did they fail as the car being driven/towed backwards?
The only other thing I can think of is were the bolts actually home and tight, or had they bottomed out allowing a gap between the head and the large washer/plate? If there was a gap it would allow the comp strut to move back and forth in the TCA and hit the head of the bolt, eventually knocking it off as your pics show..... Also, was there a small washer fitted under the head?
Might be worth contacting Compbrake as I am sure they would appreciate the heads up, and Tony will be more than helpful I am sure in resolving this.
i dont think any washers were supplied with my ones, so im pretty sure there are no washers on them.
the bolt is like 20mm max long, and the thickness of the end plate is about 5mm, then you have the gap of the tca bit where the old bushes would go,, so all in all there is only about 10mm of the thread going in to the strut. imo i would like more lol
Old 21-06-2009, 12:44 AM
  #42
andy escos
andy escos's Avatar
i used the bolts that were supplied with the kit,& ive tryed to get hold of comp brake ,ill try again monday.
Old 21-06-2009, 08:40 AM
  #43
t4 and greys
cosworth gimp
t4 and greys's Avatar
bolt or allen key cap-head will be under load surely under braking
still just unlucky tho id say , and maybe like stated a bad batch of bolts ??
Old 21-06-2009, 08:44 AM
  #44
blacky.
blacky.'s Avatar
the bolts are under load on acceleration not braking
Old 21-06-2009, 04:48 PM
  #45
andy escos
andy escos's Avatar
its a 4x4 cossy so under acceleration not that i was
Old 21-06-2009, 05:38 PM
  #46
JTECH James
Passion for Fords!
JTECH James's Avatar
if you were reversing and braking it would pull on the bolts
Old 21-06-2009, 05:40 PM
  #47
Stu.H
Stu.H's Avatar
Quite lucky, Andy!
Old 21-06-2009, 05:48 PM
  #48
Kestrel77
Alive
Kestrel77's Avatar
Darned Fortunate Bud
Old 21-06-2009, 05:49 PM
  #49
dojj
Resident Wrestling Legend
dojj's Avatar
Originally Posted by andy escos
only one bolt wascracked & rusty the other one was perfect ,i can see why the rusty one brokeit was only holding on by a very small amount but why did the other one brake
out of sympathy?
  #50
RWD_cossie_wil
RWD_cossie_wil's Avatar
I don't know, would the pull of the torque against the wheels balance out with the drag of the tyre against the road?
Old 21-06-2009, 05:51 PM
  #51
andrewg
andrewg's Avatar
suprised they are 12.9 and zinc coated? that usally takes the strenght out them,,i always use uncoated 12.9's
Old 21-06-2009, 05:52 PM
  #52
andy escos
andy escos's Avatar
JAMES OLD CHAP ITS 4X4
Old 21-06-2009, 05:53 PM
  #53
andy escos
andy escos's Avatar
Originally Posted by dojj
out of sympathy?
Old 21-06-2009, 05:54 PM
  #54
RWD_cossie_wil
Originally Posted by andrewg
suprised they are 12.9 and zinc coated? they usally takes the strenght out them,,i always use uncoated 12.9's
Serious question, why would a coating take the strength out? The coating is to prevent dissimilar metal corrosion, and is only a few microns thick? Aircraft are built with them, so can't be that bad?
Old 21-06-2009, 05:55 PM
  #55
andy escos
andy escos's Avatar
ITS WHAT CAME WITH THE KIT BUT THANKS ANDY THATS WHAT ILL ASK FOR TOMORROW DOWN THE NUT & BOLT SHOP
Old 21-06-2009, 05:56 PM
  #56
andy escos
andy escos's Avatar
Ive got a few friends with them & they all have 10.9 black bolts
Old 21-06-2009, 05:57 PM
  #57
andrewg
andrewg's Avatar
also i usually take them out to m12 as i've never liked the look of them
  #58
RWD_cossie_wil
I have black bolts with mine as well, compbrake kit.
  #59
Rob..
J496AEV R.I.P
Rob..'s Avatar
SHIT THE BED!
Old 21-06-2009, 05:59 PM
  #60
andrewg
andrewg's Avatar
dono thats what my bolt supplier told me when i asked for 12.9 plated,,
Old 21-06-2009, 06:01 PM
  #61
andy escos
andy escos's Avatar
im going to the local machine shop tomorrow to see how much to make new bits so i can have more thread coss the bolts are very short & go to m12
Old 21-06-2009, 06:17 PM
  #62
dojj
dojj's Avatar
if there is nothing connecting the other side to that, then why would it brake at exactly the same place and at the same time if it wasn't doing a wildcat non union approved walk out?
perhaps there was an issue with the bolt heads from before that caused the snapping or perhaps it was the long down time?
Old 21-06-2009, 06:21 PM
  #63
andy escos
andy escos's Avatar
i cant see what a long down time would do
Old 21-06-2009, 06:22 PM
  #64
JTECH James
Passion for Fords!
if its 4x4, or 6x4 or 8x8, the compression strut is still the component that holds the wheel in the arch, when you brake it will still pull on the bolts if your going backwards because the wheels will want to go forward, which they did when the bolts broke
i would also drop the struts to make sure the tops havent been damaged when they were pushed forward
Old 21-06-2009, 06:41 PM
  #65
andy escos
andy escos's Avatar
they broke when i was going forwards up the drive james & yes ill check the top mount bearings
Old 21-06-2009, 06:42 PM
  #66
costina
Live long and prosper!!
costina's Avatar
This thread should be read by all who fit shiney stainless bolts to there cars suspension
If a high tensile bolt can fail like this then a stainless item which is more brittle has no hope
Glad it happened like that Andy and not at speed
Paul
Old 21-06-2009, 06:59 PM
  #67
andy escos
andy escos's Avatar
Paul
hi paul the bolts fitted werezinc plated high tensile 12.9 socket cap bolts (NOT STAINLESS ) but yes very lucky indeed.
edit sorry paul just read it again quiet right
Old 21-06-2009, 07:01 PM
  #68
JTECH James
Passion for Fords!
either way, scary, and fooking lucky
tbh, i dont think i would ever have faith in them after seeing that
Old 21-06-2009, 07:18 PM
  #69
andy escos
andy escos's Avatar
i havent got faith in them im going to the machine shop tomorrow to see about a redesign with more thread & m12 bolts
Old 21-06-2009, 07:20 PM
  #70
JTECH James
Passion for Fords!
makes you think doesnt it,
did you ring me last night? i was staying at swms
Old 21-06-2009, 07:27 PM
  #71
andy escos
andy escos's Avatar
no not me m8didnt ring anyone
Old 21-06-2009, 08:27 PM
  #72
MadMac
MadMac's Avatar
Bloody hell, lucky escape on that one, dread to think what could have happened if you was on the road.
Old 21-06-2009, 08:36 PM
  #73
fordrallycar
fordrallycar's Avatar
Iam going to fit these to my car so i think i will ring compabrake to find out if they have had this problem before
Old 22-06-2009, 07:13 AM
  #74
andy escos
andy escos's Avatar
im ringing them today
Old 22-06-2009, 08:05 AM
  #75
TurboShed
Cossiemodo
TurboShed's Avatar
OMG reminds me of when my balljoint went, I was doing 20mph thank fuck.
Old 22-06-2009, 08:58 AM
  #76
Rs Gary
Rs Gary's Avatar
when a bolt is hardened or zinc plated you can get what is called hydrogen embrittlement,i am an elctroplater and do zinc plating and have come accross this once or twice,this is why seat belt bolts are not plated here is a link to it if you want a read
http://corrosion-doctors.org/Forms-H...rittlement.htm
cheeRS gary
AKA shrek
Old 22-06-2009, 09:01 AM
  #77
Graceland
Team HOTHOT!
Graceland's Avatar
I'd be more concerned about the bolts being fully threaded aswell - for the load and type of application they are in you need partially threaded bolts with the unthreaded/shoulder part being the load bearing piece to avoid this sort of thing happening!
Old 22-06-2009, 09:02 AM
  #78
3i-bays
3i-bays's Avatar
jesus, ive just put some stainless ones on my mk3 escort for the rear tie bars, prehaps not a good idea ???
Old 22-06-2009, 09:05 AM
  #79
Graceland
Team HOTHOT!
Graceland's Avatar
Andy - if you want me to, I can get you some 12.9 black M12 socket caps (what's the pitch? standard 1.75, 1.5 fine or 1.25 fine?) in the length you require and whatever "unthreaded" length needed aswell (at a guess, 5mm unthreaded in this case) for pennies - let me know via PM if you need them as I can have them to you on Weds if you need?
Old 22-06-2009, 10:24 AM
  #80
andy escos
andy escos's Avatar
graceland thanks for your kind offer but i got some new black m12 12.9 socket cap bolts this morning & im going to drill & tap the bracket out to suit should,nt break then ,just makes me feel happier knowing there m12 & not m10 .
Quick Reply: aaarrrrggghhhh crap ( all fixed now)A WARNING TO YOU ALL BE AWARE
