FAO MARKK. REF: Pectel T6 2000 Maps enclosed....
Old 23-02-2008 | 07:34 PM
  #121
DazC's Avatar
DazC
As soon as I have sorted out my loom, I am ordering an SQ6 Mark.
Old 24-02-2008 | 12:56 AM
  #122
markk's Avatar
markk
have you seen the price with it fully unlocked ? i have and its on a par with the best motec - its going to be a hard choice, no other ecu comes close, although i have had a tip off from a friend to look at the life racing F88 - if only there website wasnt shite
Old 24-02-2008 | 02:36 AM
  #123
DazC's Avatar
DazC
from what i can tell, life racing's F88 is the SQ6 in drag. I was quoted a similar price to the T6.
Old 28-02-2008 | 04:52 PM
  #124
RickyLee53's Avatar
RickyLee53
There are many management systems out there. It's impossible to say which is best.
Old 01-07-2008 | 11:49 AM
  #125
Stu @ M Developments's Avatar
PassionFords Creator
BTTT for readers of another topic who may be interested in it...
Old 01-07-2008 | 12:19 PM
  #126
DazC's Avatar
DazC
Today I am off work. So it is my mission to speak to Pectel and Life to work out which is the best ECU to go for.
The F88 will run DBW Mark! Also the F88RS without EGT is £1400 plus VAT or over 2k with! The F88RS will run DBW too.
Old 01-07-2008 | 01:15 PM
  #127
polly_x's Avatar
polly_x
What exactly is your project that you need such a mega ECU for?
Sounds like your trying to get the Millenium Falcon running again.........
Old 01-07-2008 | 01:20 PM
  #128
DazC's Avatar
DazC
I like to play with things. The car will initially be pretty basic in terms of using the ECU to full advantage but I want to play with things and add things to the car.
Old 09-10-2008 | 03:44 PM
  #129
capri-rs's Avatar
capri-rs
what make and model will u guys use the throttle body of for dbw?
bmw?
Old 09-10-2008 | 04:42 PM
  #130
andrewg's Avatar
andrewg
Originally Posted by markk
is such a short space of time how things have changed, there are now better ecu's available, the SQ6 has eclipsed the T62000 for a start, so whats the new choice of ecu ?
for me it has to be either the fully loaded SQ6 or the Motec m4000
would that be a different connector from T6??
Old 09-10-2008 | 04:49 PM
  #131
capri-rs's Avatar
capri-rs
yes
Old 09-10-2008 | 05:32 PM
  #132
markk's Avatar
markk
bmw?
VAG im using, which is a bosch unit, bolts straight onto a cossie inlet, if your using std inlets, T6 will not do DBW.
iirc it is a differant plug andy,
Whilst your here, you sent me a couple of tubes with bends and scallops in for my rear ARB mounts i think, but cant see where they weld to ?
gambo08
04-02-2016 10:49 PM
01-11-2015 06:53 PM
07-10-2015 12:56 PM
little bram
27-09-2015 07:45 AM
jay030787
25-09-2015 01:38 AM
Quick Reply: FAO MARKK. REF: Pectel T6 2000 Maps enclosed....
