spark but no injectors
can anyboy tell me what tells the ecu to give power to the injectors as cant get car started.have fuel have spark but have no power to injectors.have connected a led to injector plug to see if there getting power,every now an then the led would flash but its not constant as it should be
cheers mark
cheers mark
Check the all the earths in the engine bay, my frst wouldnt start after a 4 year rebuild. was an earth on the drivers side inner wing. All the pumps primed, plugs fired, just injectors wouldnt work.
YES I KNOW I CANT SPELL
cheers mark
cheers mark
its a 3dr cos,just done a build up,car was running,parke it in garage overnight went next day to start it and it wou'lt start.if cps(tdc) does spark then what does phase sensor control?
does anybody know for sure which i.e. phase or cps sensor controls injectors so i know which to try first
Team HOTHOT!
I was under the impression that on the L1 ECU loom the "power" feed for the injectors came from the fuel pump relay and then the injectors are switched to earth by the ECU in order for them to fire.......
Might be worth looking for your 12 volts and work from there........
Team HOTHOT!
Infact, looking at wiring diagrams, all the cossie wiring looms are like this - 12 volt feed from the fuel pump relay once the ignition is on......
when you first click the ignition on the led i put in injector socket lights up but then it goes off ,so you say the best place to check is the fuel pump relay.
can you tell me where i can find such relay?
could this also be a bad earth?
as the fuel pump is priming?
ive ordered a new tdc/phase sensor today from matt lewis so when they get here im gonna whack them on gap them properly and see how it goes.
here we are
try this, i use this info all the time very useful
http://www.cannell.co.uk/Ford_Worksh...sis%20Info.pdf
here we are
this sounds like the same problem i have can not get ecos started turning over alright but wont fire up...have you had the car started since rebuild mate? im just pissed off at this stage tried and checked everything, hope you get her started, cheers hugh
mk3ste
17-10-2021 10:09 AM
DixieTheKid
11
06-06-2020 11:20 AM
deathrider666
28-09-2015 06:12 PM
