Brake problem
Old Jun 14, 2009 | 10:50 PM
Drunken Master's Avatar
Drunken Master
Default Brake problem
I've just fitted some new rotors on the existing bells I've used new bolts etc and it's all been torqued to the right settings. I'm using a newish set of pads from the old discs that had cracked.
Now I've been out to bed them in and it looks as if only the bottom and top of the disc is meeting with the pad it looks as if the middle has had no contact at all.
Do I need new pads?
Old Jun 14, 2009 | 11:17 PM
burnzy's Avatar
burnzy
burnzy
you could try with a bit of sand paper on some wood "a flat surface" and then give them another try, tbh it just sounds like your pads have contoured to your old rotors so flatting your pads down a little should do the trick
*edit* or if it doesn't bother you another set of pads would cure it straight off, but depends if there is still alot of meat on the old set and don't wanna just bin them
Old Jun 15, 2009 | 06:17 PM
Drunken Master
What kind of sandpaper would you use?
Old Jun 16, 2009 | 04:21 PM
Drunken Master
Any help on this would be apprieciated. Take it you mean a pretty rough/corse sandpaper?
yatta
May 21, 2016 10:31 PM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
focus2351
Sep 9, 2015 09:33 PM
routemaster
Sep 7, 2015 05:27 PM
cossirob
Sep 3, 2015 09:17 PM
