2.0 zetec bike carbs
been offered bike carbs for my car but how easy is the conversion i obviously know i need an inlet made up but do i need management to run them or do i just need them set up any help much appreciated
With carbs you won't need management, but with throttle bodies you will, if fitting carbs you will need to sort the ignition side of things, if going tb's might as wll just use a ecu that does it all anyway.
As said tb's so much better driveability generally than carbs.
mk3ste
17-10-2021 10:09 AM
07-10-2015 12:56 PM
