p8,greys,coil packs etc?
is there a guide anywhere? i have a 2wd cossie currently on yellows and l6 ecu,the engine has been freshly built and run in but now i need to fit my goodies
i have grey injectors, a p8 ecu with antilag and modded throttle body,new leads and coil packs basically im a little unsure how i should be attempting this install any help would be greatly appreciated
You will need to swap the top & bottom tps wires round fit a 4x4 tps sensor ,totally disconnect the old coil get the driver fitted to the p8 ecu for coil pack fit the twin ignition amps & wiring its pretty straight forward i have the same set up on my 3 door.You will need to re wire your rev counter ryan on here will tell you how to do that as i got him to make me a complete loom for the car with coil pack wiring.
Throttle body is straight forward replacment, the anti lag im sure is switched from a pin on the ecu , i have antilag on mine would also like to know how to wire this up
the car will also need professionally setting up after all the bits are installed mate so you may be better off spending a bit of extra cash and getting the pro to fit all the bits aswell. at least then youll have peace of mind that its been done proerly
07-10-2015 12:56 PM
