Turbo union size???
03-06-2009, 07:08 PM
Live long and prosper!!
Turbo union size???
Does this matter ie the internal diameter of the union which bolts on the turbo and then the feed pipe
Reason i ask is a m8 who runs a 2.9 twin turbo wonders why it smokes on idle?
All comments welcome
Paul
03-06-2009, 07:31 PM
if its to big turbo will smoke if it old when fitting a roller turbo you need a 1mm hole as it will smoke
03-06-2009, 07:35 PM
should be restricted to about 1.8mm
03-06-2009, 07:37 PM
Dave turbos are new but they have a 6mm one in them atm and i thinking the oil choice is a big no no ie 20/50 mineral
Guzzler thanks
Paul
03-06-2009, 07:40 PM
i 'may' be able to find you some, i'll have a look tomorrow.
03-06-2009, 07:42 PM
6mm no wonder it smokes m8
03-06-2009, 07:43 PM
Quote:
Originally Posted by
GUZZLER
That would be a great help
Thanks
Paul
03-06-2009, 08:08 PM
i have one here m8 if any good to you
03-06-2009, 08:39 PM
only reduce for roller bearing thou!!
03-06-2009, 08:52 PM
cossiedave
Ta Dave will let u know
Paul
03-06-2009, 08:54 PM
andrewg
Thanks Andrew there not roller bearing so hopefully union size and oil should cure it as both turbos are new and it only does it on idle once up to temp
Paul
05-06-2009, 04:56 PM
All sorted now with a change of oil to semi and some restrictors fitted
so thanks to everyone for there input
Paul
Matt Baxter
16-09-2015 08:30 PM
lee2cossies
26-08-2015 10:04 PM
muz
16-08-2015 12:57 PM
marky_g
03-08-2015 04:45 PM
