Brake caliper mounts - alloy grade?
Any engineers know the answer?
I need to machine up some mounts for wilwood powerlites. Due to the lug mounts on the uprights and the radial mounts on the calipers sharing fixing centres I will have to tap the radial mounting bolts into the alloy adaptor. These will be tpped to a depth of about 20mm on an M10 thread.
Can anyone tell me what grade of alloy bar I should be using (need 20x40 bar) and also should I helicoil it ( only 1.5 times dia deep iirc) and am I best to use standard or fine pitch bolts? Fine is better for torquing up, but caure pitch might take a better thread in the aluminium?
STOP!... Carry on
unsure as to the rest of the answers, but dont tap ally in metric fine... the threads will rip out. metric coarse FTW.
Heli-coils will add strength to the thread and i would recommend them, just incase you have to do runnig repairs!
put some copper slip on the bolts going into the tapping block, as the steel and ali will react, causing the bolt to be hard to remove in the future!
hope this hels a little!
Job done. I think the powerlite uses a BK56 mount bracket but best check with them.
Stu
do they have off the shelf items for mazda mx5 uprights?
I fugured with the thread pitch. not sure if 2x diameter in alloy or 1.5 times diameter in helicoil is better, the helicoil is only threaded into the allow afterall!
Point taken on the copperslip, altho Ill probably use loctite for peace of mind but it whould provide the same effect
HE30 is easy enough to get. Any particular reason? I have no ideas of the properties so any extra infirmation is always interesting!
