converting MFI to EFI where can i get that plate?
just bought an all steel n/a ZVH, thing is its on MFI, and i want to put it in my EFI rally car! where can i get hold of that plate that goes between the head and the manifold on the efi to clear the injectors? sure i've seen one before but cant remember where!!!? also if anybody can think of anything else im gonna need that would be great! i think i need the plastic core pug that goes where the dizzy on the MFI went, where the coilpack plate is going now. dont know where to find that either!!im assuming gen ford.
I got mine off of ebay. I'm doing a 1.8 ZVH EFI Turbo on my Orion. IIRC it was around Ł60 inc postage, i only got it a couple of months ago. Message the seller "ginandtee" as I know they got a few made up when I got mine.
It was a perfect fit.
good good, i have dealt with that seller before. where do i get that plastic core plug thing where the dizzy went before .IE behind the coilpack from?? and did you use longer manifold studs and two gaskets for that plate??
I used two gaskets yes, one efi one, and one mfi one. I will be replacing the studs with stainless bolts, for short term I have just used exhaust manifold studs. They're not quite long enough but do hold it ok if you get the nut right on the end of the stud.
