helpppppppppppp me
How the fook do you get a 4x4 cossie downpipe back on
just took my power engineering system off to fit 2wd manifold and mongoose exhaust,the size difference in the downpipes is shocking
But i cant get the new downpipe back on grrrrrrrrrrrrrrr
need it done tomorrow so any hints and tips would be great
here is a pic to show the size difference
you can just drop the anti roll bar mounts,that will give you a bit more room.
you have to get the car as high as you can too as you have to twist and turn the downpipe under the car to get it to fit in there.
have you put a 2wd ex manifold onto your car as i put a 1-2 inch extention in my downpipe to give me a bit more clearance,hope you will be ok.
i done a gearbox the other week on a 4x4 saph and i had it jacked up maximum height on axle stands, about 10 inches high guessing, i did drop the anti roll bar and it made it easier for me, just drop it from the mounts and leave it bolted to the tca's
when putting the anti roll bar mounts back on, jack the anti roll bar up in the middle so you can line up the 2 brackets with the holes in the chassis,a lot easier that way.
oh, when taking the mounts off, undo a bit of each bolt at a time or it will be hard to get a socket on the other bolt, if you take one fully out,the arb will push the bracket down and you cannot get at it.
well I got no calls dave so he must have sussed it!
untill he turns a corner and finds out it's too close to the prop or chassis and it clonks all the time lol
like mine did on my saph years ago till I sussed what the noise was!
steve
steve
yep all fine, goes like fook now
someone in a white van flashed then waved me earlier, not sure if it was davecos4x4 going towards seaton, i didnt get a proper look while i was driving along, could have been anyone
Sarah
Sarah
