any electricians about!!
Hi my next door neighbour is after advice about her heater for her outdoor pool.
Its a 5kilowatt unit , whats the best/safest way to power it? will it be fine just plugged into mains or should she have it rigged into the mains via its own fuse board etc....
forgive me if this is a daft question , wot i know on electrics i could write on a pin head.
any replys much appreciated ,mike
5kw will be pullin about 22 amps so if its pluged into a 13 amp socket it will blow immediatley. its gona need probably a 32 amp 4mm supply on a 30mA rcd
you need to work out the volt drop for the cable distance,how many amps does it run,how many meters away from fuse box and it will definatly need an rcd,,in,the 17edition wiring regs there is a section devoted to swimming pools,post up the amps and distance in meters and ill work it out for you
I had this problem when i wanted a 9kw heater, tell her to buy a 3kw heater then it can be plugged into a normal plug depending how far the cable run is
rated voltage 220-240
rated power 5000 watts
frequeny 50 hz
cant see how many amps it runs !!!
5000 divide 230=22amps,you can get away with 2.5mm,but id use 4 mm with a 30 milliamp rcd protecting it and a 25amp mcb.if in doubt get an approved sparky in to do the job as swimming pools are like bathrooms and have zones that you have to use certain types of ip rated equipment in
which make boards do you use ive never seen a 25a mcb personally ???
sit boo boo sit
job will have to be done by a part p registered sparky as not only is it a notifiable job its government legislation it be done by one
end of
thanks everyone for ur views and info on this , i,ll pass it all on and leave it their hands.!!!! its one for the pro,s so its nice she,s now got a got idea it whats involved.
job done
any ideas on cost of this setup ? roughly . sounds like quite few hours job to me
job done
sit boo boo sit
job done
job done
to do right yes it wont be cheap but unfortunately there are lot of lads about will do it cheap-but you know what you will get in the long run if they go down that route
really annoys me at the moment that the layman knows nowt about part-p but all about what was corgi (but thats another argument)
without seeing i wouldnt imagine they`ll get much change from Ł500-Ł600
that is site unseen tho
i get out quite often thanks, just never seen one hence the question
Run directly from the fuse board on its own circuit yes. Would be live coming out the fuseboard then i would suggest putting an isolator at the swimming pool (a switch to turn it off) for ease of use.
van_dogg_pavvy
03-03-2016 09:30 AM
geoffxr4
02-11-2006 09:00 AM
DaveEscos
11-02-2005 11:33 AM
