Are spec R breathers
Live long and prosper!!
Really that bad? reason i ask mines always getting blocked and even once i have cleaned it, the car still produces more crap out the back on boost and a lot less with the main block breather pipe disconected from it
The car has done big miles but i'm putting most of it done to not breathing enough
Ideas and suggestions please people
Paul
Paul
If the car's done big miles then i'd bet on the fact that the car does actually breathe heavy and has plenty of crankcase pressure.....only so much a breather can do to mask/help the effects!
had mine custom built by bailey for my zetec turbo and when i cleaned mine it had hardy any oil in it and only ever dropped a few spots of oil when on full chatter out of the drain at the bottom of the tank , the spec-r ones always look far to small to me as they look like standard fiesta turbo ones in size , mines about twice the size , cant be that good on a 500+bhp engine surely
i dont know fuck all about how the cossie engine breathes to be honest so if you say its fine then the spec-r must be a good bit of kit , just looks small thats all in my opinion
cheers paul
Just spoken to Pete @ Spec-R and this is what he had to say on the subject (he cant get to a PC at the moment)
the early seperators were 2 1/4". With the advent of bigger BHP engines and different oils these were quickly superceded by a 3" seperator approx 3-4 years ago.
Pete had said that he has had never had any bad feedback in regards to either the 2 1/4" or the 3" seperators and both these sizes have been used on big BHP Cossies.
If you are using one of Petes universal seperators this will definately be a 3".
This would suggest to me that the problem is definately not with the breather but Pete has said you are more than welcome to give him a call where he can take you through some of the possible causes.
I personally have a Spec-R oil breather system on my 3 door and have never had a problem with it.
