skyHD box kaput
skyHD box kaput
the telly was on, the next thing you know, the box has switched off, just the little red light showing
even after leaving it uplugs for 15 minutes has not resluted in any life being in the box
is it fooked?
will i have to tell sky to cancel unless they give me another one?
etc?
is it fooked?
etc?
rich_bloor@hotmail.com
Your box has gone into 'safe mode' and only a technician can bring it out. its protecting its self from fucking up good n proper as it has a fault.
ring sky and tell them to give you a free service call, any service call you get will have a box allocated to it and it will be with the engineer when he calls at your house. he should just swap it over and pair your card for you.
If sky say you can't have a 'free service call' just tell them you want to quit. Stand your ground, even if they put you through to cancellations. They give in to you in the end. Standard service calls cost approx £70.
Worst case scenario, they will cancell your contract, but they will inundate you with offers to re-join within a month. although, it railey goes this far.
95% of the time, they will just send someone out to you for free.
I have just repaired my sky hd box myself. It started loosing signal and got loads of random shutdowns. Opened it up and 4 out of 15 capacitors on the PSU were bulging, replaced all the capacitors and its been fine ever since.
Its a common fault with the Thompson HD boxes have a look on Satcure for replacement PSU or a capacitor kit.
st170 breaking
they come apart easy but shit loads of little screws
ive got a good set of boards if you need 1, ive used the hdd in a pc and the casings looks good as a place to hide my stack of v5's from the missus
is it fooked?
etc?
is it fooked?
etc?
Steve Escos
01-10-2015 06:57 AM
deathrider666
28-09-2015 06:12 PM
Russ Payne
25-09-2015 08:29 PM
