General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
hi mate ian howell is still making them for a short time so get in quick they are £650 but this is rated upto 500bhp+ . thses manifolds use a jenvey inlet manifolds with custom built thick walled alloy casings with take offs for vacuum etc and can be made to suit any size throttle body your going to use , they can also be built for 4 or 8 injectors they have rolled trumpets welded inside for greater airflow and built leftor right . just speak to him on tech@fiestafrenzy.co.uk
heres some pics of mine
cheers paul
Are those inlet manifolds for zetec turbo's only or does he make them to fit a cvh??
yes mate he makes them for both zetec and cvh as sid on here is one of ians best mates and hes running one , again contact ian on tech@fiestafrenzy.co.uk he will get back to you just give him chance to reply but he is only making them for a short time then thats it so get in there quick and just to add this manifold has spent many hours being designed and developed on a superflow flow bench that ian brought himself at great cost so he could make the perfect flowing inlet manifold , its alright just welding alloy parts together , it makes sense it will flow more air than the standard inlets as they are much bigger , but it does start to matter when your running decent horse power as this manifold is equal across all 4 cylinders and is provern, sounds expensive but you again pay for what you get (a proven product)
cheers paul
