more power
would that require a engine rebuild..i think its got 500 style intercooler. a t3 no good if t34 wat kind of power with greens and 31 act could ya remap standard brain or chip aswell.. cheers
a t3 will probably make 330 at a push, but you'll be ringing its neck all the time, and it might not last long.
therefore i'd go t34.48 if you want it to be a proper stage 3 with a -31 actuator, very quick road car.
you will need a chip.
dont neglect other things tho, e.g. make sure your fuel pump is rewired for a direct feed from the battery and get a decent oil breather
14000+ post superhero
you dont need a rebuild unless its fooked or a t34 for stage 3, greens , chip , map sensor is all you should need and youll get that for about £400-£500
im a bit green on turbos, had ya m3 m5 xjr jags, this cozzy has me by the family jewels,, totaly lovin it.. can ya up rate the standerd oil cooler, fuel pump to switch live..
deathrider666
28-09-2015 06:12 PM
