electronics experts
Old May 17, 2009 | 10:33 PM
markk's Avatar
markk
Default electronics experts
I need a good quality 5k pot for my traction control, can anyone point me in the direction of such an item ?
also 5k seams a lot less common than a 4.7k, why is this when its only 300ohms???
Old May 18, 2009 | 06:44 AM
rik-rs's Avatar
rik-rs
http://www.rapidonline.com/Electronic-Components/Resistors-Potentiometer/Control-Potentiometers/1W-Single-turn-precision-potentiometer/65229/kw/5k+pot
Old May 18, 2009 | 01:44 PM
GARETH T's Avatar
GARETH T
whats it being wired into? im sure the 4.7 will be fine
Old May 18, 2009 | 03:12 PM
markk's Avatar
markk
cheers
variable input adjustment for traction control slip function.
Old May 18, 2009 | 03:40 PM
ECU Monitor Enthusiast
Ditto
Old May 18, 2009 | 03:43 PM
cjwood555's Avatar
cjwood555
4k7 is in the most common 'preferred value' series, hence there being loads of them. Is there not one supplied with the system?
Ignoring the above, There are >300 5K pots listed on Farnell's website! They range from iddy-biddy ones like this to chunky ones like this.
Downside to using Farnell is the Ł5.95 handling charge for orders below Ł30, though you could easily make it up to that with sleeving, cable, etc....
Bear in mind the Rapid one linked to above doesn't say whether it's linear or log taper. Would assume linear as it mentioned 'linearity' in the spec, but could also be an odd spec relating to tolerance along the track for a log taper.....
Chris
Old May 18, 2009 | 03:53 PM
markk's Avatar
markk
to be honoust a switchable pot would be nicer, say 6 positions spread across 5k, would make the settings more repeatable in a standard position, do they do any?
ive seen the switches that you put the pin in to decide how many positions, the i suppose i could just make the positions up with resistors maybe ?
cheers all !
Old May 18, 2009 | 05:12 PM
GARETH T's Avatar
GARETH T
cheers all !
yes mate, you could do that!
Old May 18, 2009 | 05:42 PM
cjwood555's Avatar
cjwood555
That'd do you - resistance is steps of 0R, 1k2, 2k4, 3k6, 4k8.
Switch is RS part 352-250 for the wafer and RS part 352-187 for the mechanism.
Would suggest going for a 6 way switch though as that's where the stops on the mechanism are... Then just use 1K resistors and you'd have 0R, 1k, 2k, 3k, 4k, 5k....
Hope that helps,
Chris
Old May 18, 2009 | 07:48 PM
markk's Avatar
markk
Hope that helps,
Chris
absolutley superb, thanks very much
Old May 19, 2009 | 01:12 PM
cjwood555's Avatar
cjwood555
No probs
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
cossie brad
Sep 29, 2015 02:38 PM
DavidK
Sep 27, 2015 02:55 PM
dombanks
Sep 21, 2015 08:38 PM
markk
Sep 9, 2015 08:11 AM
