Handbrake light staying on - help¬
Old 17-05-2009, 08:42 PM
smudge_lad
smudge_lad's Avatar
Default Handbrake light staying on - help¬
As title, my handbrake light has decided to stay lit constantly.
What should I be checking?
Keir
Old 17-05-2009, 08:43 PM
Stu.H
Stu.H's Avatar
Switch under the carpet by the handbrake.
Old 17-05-2009, 08:58 PM
Oranoco
Oranoco's Avatar
Brake fluid level?
Old 17-05-2009, 09:10 PM
smudge_lad
smudge_lad's Avatar
Can you ellaborate a bit on that mate?
Can I get to it without lifting the carpet?
Where exactly is it? And can it be fixed, or does it need to be replaced?
Keir
Old 17-05-2009, 09:18 PM
ste45
ste45's Avatar
mine used to do that , was sumat to do with the abs
Old 17-05-2009, 09:19 PM
cossiegreg1
cossiegreg1's Avatar
check fluid first then check switch under handbrake
Old 17-05-2009, 09:20 PM
orionmojo
orionmojo's Avatar
if you've got a handbrake surround or gaitor, remove it. peel back the carpet and you'll see a black clip on a green and brown wire (on the drivers side) you'll probably need a small screwdriver to do it but try and push it back on if its loose, mine was intermittent for ages, then NMS fixed it
IainRS1700T
25-09-2015 06:44 AM
Flatlinedan
18-09-2015 12:41 PM
The Enigma
12-09-2015 10:12 PM
morg65
Escort MK 5 / MK 6
11-09-2015 01:55 PM
wheelwizardrefurbs
05-09-2015 10:52 AM
Quick Reply: Handbrake light staying on - help¬
