Burton power have had us over
The new pinto high pressure pump from burtons cant be used in a cossie lump now just by using the cossie top plate and pick up, the casting on the case has been changed so 2 of the holes dont line up at all and no room for machining the top plate holes to fit they've done a proper job, also you cant get away with cleaning your exhisting case up and use the internals from the new pump as the main impella with shaft has been tapered so it wont go in the old casing, just thought i'd let you guys know i think its a twattish thing to do coming from a ford performace so called specialist, i shant use them again for anything now as its been done on purpose to make people spend the money on yb pumps.
i had probs with them a couple of weeks ago, customer service is a joke there imho!
i wont be using them unless i am desperate and no other choice, even then i wouldnt hold out any hopes of them being any use!
Carbon Crazy
ie your pretty much just paying a "cosworth" premium on the pumps when the pinto pumps seem to work ok from what coswurv is saying. And obviously burton have cottoned onto this changing pump design so it cant be modified to fit cosworths, ie to make more profit.
cosworth YB is a development on from the pinto engine with an added alloy 16v head as well as other mods.
pinto h/p £39
2wd h/p £169.95
so a massive difference beings the internals are identical, its a shame is all im saying, instead of doing this why dont they just continue to label the pinto pump up as 2wd cossie and price it at say £75 that way they will shift loads and not have to buy the yb pump in which must cost alot more, as they have the pinto pump cast themselves so ive been informed.
pinto h/p £39
2wd h/p £169.95
2wd h/p £169.95
that is f###in scandalas, £100 cosworth tax is ridiculous imo. i dont mind paying what stuff is worth but theyve blatently added cosworth tax
14000+ post superhero
cant the tampering done to the internals of the pinto pump be undone to allow the fitting of the internals to your old casing?
or buy from somewhere lese that doesnt do this?
if people can't afford cosworth parts don't buy a cosworth, i'm pretty sure if you send it back and speak to barry he mite do you a deal on a cosworth pump
Theres been a difference between there pumps for years,
i have a new H/p 2wd and pinto pump from burtons. and they are different, the cosworth one is alot better made. but not the 100+ quid better tho.
I used to use Burtons all the time, everytime, but the prices crep'd up,the discount i was getting was getting less, so i havent used them for years now.
Never had a issue with there customer services tho. Even tho their advice could be wrong, but no different to other places.
stupid in what way sounds like burtons have been having their selfs over losing money, yes it is a dear pump but it's got cosworth on the box, your paying for the name not the product
Live long and prosper!!
But to be fair Burtons is the only place who now produces parts that are no longer available ie the twin cam stuff and pulleys
At the end of the day as the cars get older prices will go up,for example i'm after some cortina mk 3 wings but at £300 each form certain places and pattern part fetching silly money on ebay it will have to wait
You could always fit zetec spray jets and use a std pinto pump as the small turbo yb
Paul
Paul
deathrider666
28-09-2015 06:12 PM
