what sub box do i need?
Old May 15, 2009 | 10:36 PM
FIESTA CHRIS H's Avatar
FIESTA CHRIS H
Default what sub box do i need?
Hi I have recently bought a 12" jl audio JL W3 sub and need a sub box to use it. Ideally id like a ported box but im not sure if you can get different sub box's with different depths and im not sure wots the best sub box to get the most out of the sub. Has anyone used this sub and wot box did u use. Does anyone know if bassboy makes sub boxs or buys them in and roughly how much would one cost basicly i dont know whether to get a box off ebay or buy one more specialised for the job?
Old May 15, 2009 | 11:29 PM
mrjenrst's Avatar
mrjenrst
or make one?
Tbh some you can buy are fucking shocking.
Get the jigsaw out mate
Old May 16, 2009 | 09:16 AM
zetecdan's Avatar
zetecdan
there's some info here,
http://www.the12volt.com/caraudio/boxcalcs.asp#rec
Old May 16, 2009 | 10:04 AM
Stu.H's Avatar
Stu.H
Did you get the 4ohm or 2ohm sub?
Old May 16, 2009 | 10:15 AM
Stu.H's Avatar
Stu.H
For a ported box, you generally need a 1/3 bigger box than a sealed enclosure.
As for exact litres on the size of the box, why not check just on the JL audio website?
here
Oh, and I hope you are giving it LOADS of juice, as these puppies are thirsty!
Old May 16, 2009 | 10:26 AM
Eagle's Avatar
Eagle
Super Moderator
bandpass or transmission line would be good .. but in a car i dont think there is enough space for the latter lol....
and yeah some shop bought ones are truly shocking, homebase cut wood to size so there is a place to start if your stuck.
nice rigid 3/4 ply or mdf braced inside makes a huge difference heavy as though nothing worse than a sub that vibrates its box ...
Old May 16, 2009 | 10:33 AM
biglee's Avatar
biglee
Audio specialist
transmission line will give you geat bottom end but for a 12" driver it would need to be 7 ft long so no chance,,, bandpass is the way for you in the boot. i would use a sealed box and drive it wiith twice RMS it needs, thats gona give you real fast tight bass which imo is what you need in a car to hear it properly. if you use a ported box it getts all wolly and far too slow etc.
Old May 16, 2009 | 10:35 AM
Stu.H's Avatar
Stu.H
Yeh, people see 300wrms on a sub box and think that a 300wrms amp will drive it sufficiently, when in reality you need 500-600wrms!
Old May 16, 2009 | 12:00 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
Sorry to jump thread, but whats best for an 8" sub?
Old May 16, 2009 | 01:58 PM
RichieST's Avatar
RichieST
The skip
What make/model is it mate?
Old May 16, 2009 | 07:01 PM
FIESTA CHRIS H
2 ohm m8
heres the spec of the sub
Tech spec:
The JL W3 range of subwoofers work well in sealed, ported and bandpass enclosures
and its dual voice coil design gives the user a high degree of application flexibility
12W3v2 DRIVER SPECIFICATIONS
Free Air Resonance (Fs): 27.97 Hz
Electrical “Q” (Qes): 0.534
Mechanical “Q” (Qms): 7.678
Total Speaker “Q” (Qts): 0.500
Equivalent Compliance (Vas): 2.806 cu. ft. / 79.47 liters
One-Way, Linear Excursion (Xmax)*: 0.510 in. / 13.0 mm
Reference Efficiency (no): 0.313%
Efficiency (1W/1m)**: 87.15 dB SPL
Effective Piston Area (Sd): 80.600 sq. in. / 0.0520 sq. m.
DC Resistance (Re): 1.658 ohm
Nominal Impedance (Znom): 2 ohm
Thermal Power Handling (Pt): 500W
Driver Displacement: 0.071 cu. ft. / 2.01 liters
AJC
Oct 8, 2015 11:09 AM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Steve Escos
Oct 1, 2015 06:57 AM
deathrider666
Sep 28, 2015 06:12 PM
Russ Payne
Sep 25, 2015 08:29 PM
