secs monitor help
14-05-2009, 09:35 PM
secs monitor help
i got a new one today from mike rainbird the throttle position on idle is 100% is this the correct reading my car is running p8 obviously when you put the foot down it it reads down is this correct?
14-05-2009, 09:36 PM
Live long and prosper!!
change the tps setting you have 2wd or 4wd tps??
Paul
14-05-2009, 09:38 PM
i have 4x4 one on my car running p8 ecu , is it easy to change the setting
14-05-2009, 09:39 PM
yes go into sensor types
paul
14-05-2009, 09:40 PM
hold the 2 buttons down carlo then use green button to go through the settings etc
Carlo read the instructions,
cheeRS stu
Cool i will have a play about with it 2 moro , i take it it should be at 0 when idle then count up in% when you put the foot down
14-05-2009, 09:41 PM
i did stu but got kinda lost in them
14-05-2009, 09:42 PM
Thanks dicko
15-05-2009, 07:20 AM
Quote:
Originally Posted by
carlo
Correct m8.
15-05-2009, 07:25 AM
STUCOS
cheeRS stu
pabloXR
21-09-2015 12:42 PM
Roscopeco
14-09-2015 05:32 PM
Bailes1992
03-09-2015 02:17 PM
K42L
28-08-2015 01:23 PM
Bailes1992
16-08-2015 07:14 PM
