Bleeding brakes help
Old May 11, 2009 | 10:22 PM
B16's Avatar
B16
Default Bleeding brakes help
Trying to bleed brakes on a 2wd saff. can get a hardish pedal when bleeding with ignition off. as soon as ignition goes on pedal goes soft again.
Any ideas please
Old May 11, 2009 | 10:49 PM
Toe Knee's Avatar
Toe Knee
have u bled them from both bleed nipples each side at the front?!
Old May 11, 2009 | 10:54 PM
burnzy's Avatar
burnzy
burnzy
work from the furthest brake away from the cylinder and work back do all 4 to make sure you'v got all the air out and maybe get a pressure bleeder it'll make life so much easier for the pennies, and don't let the res go empty otherwise you'll have to start again
Aahh! yea there 4 pot's on the 2wd aren't they yea make sure you got both sides of the caliper and work on the furthest away method still to
Old May 11, 2009 | 11:36 PM
NUTS RuS's Avatar
NUTS RuS
Bleed with ignition on and it should clear the abs modulator of air too
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
