sapphire 4x4 boost problems again
Old May 11, 2009 | 07:33 AM
cossiej's Avatar
cossiej
Default sapphire 4x4 boost problems again
we got the cossie looking great she was running 15 psi nicely on our drive to a classic car show yesterday done almost 50 miles but on the way home was popping at banging at only 10psi as soon as trying to load up the car and boost ???? any ideas why would it be ok and then not
Old May 11, 2009 | 07:53 AM
Bullett's Avatar
Bullett
jay i still think wiring mate,get them blocks cut out and soldered straight through.
unless you have an ecu problem?
Old May 11, 2009 | 08:13 AM
cossiej's Avatar
cossiej
mate i think mite be ecu trying to get hold of one to try any ideas so pissed of with it at the moment
Old May 11, 2009 | 08:15 AM
Bullett's Avatar
Bullett
damn,sold mine. trying to think who may have one to try.
you at work bud?
Old May 11, 2009 | 08:16 AM
cossiej's Avatar
cossiej
i am mate how about disconnecting the amal valve ???
Old May 11, 2009 | 08:19 AM
Bullett's Avatar
Bullett
dunno tbh.i wouldve thought if it was amal valve you would have too much boost?
Old May 11, 2009 | 08:30 AM
cossiej's Avatar
cossiej
sell it may be the way foward i really have had enough
Old May 11, 2009 | 08:56 AM
charlie luciano's Avatar
charlie luciano
When problem happens whats the rev counter doing?
Luciano
Old May 11, 2009 | 09:03 AM
Twellsie's Avatar
Twellsie
mine was doin this, the nipple on the map sensor had snapped
Old May 11, 2009 | 09:19 AM
cossiej's Avatar
cossiej
we changed the phase sensor the car revs ok the counter was abit funny but seems better since changed ..... map ok only a few months old the top of number one piston is wet and plug black as black
Old May 11, 2009 | 10:40 AM
YBJ's Avatar
YBJ
Thinking Cosworth..
Originally Posted by cossiej
..the counter was abit funny but seems better since changed .....
This and the popping noice really sounds as a bad connecting in one of the 3 connectors at the bulkboard to me..
Old May 11, 2009 | 10:42 AM
cossiej's Avatar
cossiej
thanks wim will have a look at them to nite waht bout the spark plugs etc ??
Old May 11, 2009 | 12:39 PM
Bullett's Avatar
Bullett
jay you have checke dthe dizzy havent you?if one of the terminals is fooked inside it may cause an issue. but i still say those plugs may be broken down inside.
Old May 11, 2009 | 01:17 PM
cossiej's Avatar
cossiej
i have neil we did the phase sensor as wires were broke but will check again does yours still run amal valve ???
Old May 11, 2009 | 01:24 PM
PeterLucas's Avatar
PeterLucas
Not boosting, siezed waste gate? ive had that but mine had seized shut and boost went through the roof!
Old May 11, 2009 | 01:27 PM
cossiej's Avatar
cossiej
no had the turbo of it was fine all day saturday its just the black and wet on top of no 1 piston that worries me ????
Old May 11, 2009 | 01:30 PM
PeterLucas's Avatar
PeterLucas
Poping noise might be unburnt fuel getting through to exhaust (hence wet no.1 not firing) have you tried obvious plugs & leads?
Had the plug out to see if any spark?
Crankshaft sensor gap can royally fook things up as well!
Old May 11, 2009 | 01:41 PM
PeterLucas's Avatar
PeterLucas
Also a compression check wouldnt hurt, burnt out exhaust valve would cause noise/poping through exhaust manifold.
Old May 11, 2009 | 02:42 PM
cossiej's Avatar
cossiej
leads new plugs new got a strong spark plug just very black what should the phase sensor gap be ???? oh comp ok
cossiej's Avatar
cossiej
ooops sorry meant crank sensor cap
Old May 11, 2009 | 04:01 PM
Bullett's Avatar
Bullett
jay my escort runs air injectors so no.i may have a amal valve some where but i think i sold it
Old May 11, 2009 | 04:50 PM
PeterLucas's Avatar
PeterLucas
Phase sensor is 0.2mm - 0.3mm.
Crank shaft sensor is 0.6mm - 1.0mm
Check you have the phase sensor wires the correct way round, that one got me!
Old May 11, 2009 | 04:57 PM
PeterLucas's Avatar
PeterLucas
Swap injectors see if the problem moves to the swapped piston, then you could isolate it to wiring or injector? Just a thought.
Old May 11, 2009 | 04:58 PM
costina's Avatar
costina
Live long and prosper!!
cut the connectors out and solder theses are a pain in the ass
They can cause all sorts of funny probs
Paul
Old May 11, 2009 | 07:58 PM
cossiej's Avatar
cossiej
guys thank you so much only thing havent done is the connectors and the injectors just got in after being in the garage will give her a run tommorow fingers crossed
Old May 15, 2009 | 08:52 AM
cabrio zo's Avatar
cabrio zo
From: Sudbury Suffolk, Drives: Octavia VRS & XR2i 1800 Zetec track car
We learnt that one rather quickly when first fitted it, made an awesome bang on firing her up for the first time
Jas checked the gap last night (as I'd mentioned Sunday - it'd done a few miles so could've 'moved' - especially given who fitted it ) the gap was quite big and *fingers crossed* she was running well last night (I almost gained my first 3 points )
Z
jason_nike
Aug 18, 2019 10:53 AM
SmudgerByName
52
Jul 28, 2016 06:14 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
frug
Aug 26, 2015 06:46 PM
Old ford
Jul 31, 2015 06:50 AM
