News from Brunters Cossie Thrash Today...
Old 07-12-2004, 01:11 PM
  #41
Spiky
Spiky's Avatar
he was running 38 at totb3
Old 07-12-2004, 01:27 PM
  #42
JRST
JRST's Avatar
38 psi
thats alot of boast.
  #43
Ian2wdsaffcos
Ian2wdsaffcos's Avatar
and he went to Karl's recently for MORE boost IIRC!
Old 07-12-2004, 01:33 PM
  #44
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
Well becuase of the design of the T4, he would / should have realised that more boost would give considerably higher ACTs and may have in fact reduced the amount of air flow .
Old 07-12-2004, 01:38 PM
  #45
Ian2wdsaffcos
How about if it was a really cold day in December it was being upped for though Mike
Old 07-12-2004, 01:40 PM
  #46
Ian2wdsaffcos
......in fact, didn't MADRod used to run a 42psi peak in his old 500 engine? And that was pretty rapid eh Mike
Old 07-12-2004, 01:42 PM
  #47
ImaRacing 700
ImaRacing 700's Avatar
Is Nutter running a long stud block or is this the famous NMS "only use std head bolts"
Old 07-12-2004, 01:52 PM
  #48
Karl
Norris Motorsport
Karl's Avatar
Phil,
It uses the traditional 6 long studs.
The headgasket has blown out at the front of cylinder number 1 (i.e. above the water pump) and is a failure that is associated with any dis-similar studded block. (I.e. failure caused by difference in clamping force between different methods of clamping)
Cylinder head clamping must be uniform and is why I never have recommended 6 long studding. Nutter's engine sadly adds to the ever growing list of failures I've seen on this type of head clamping.
I'm disapointed for nutter as he really wanted to crack 185mph today but only just made it into 5th gear when disaster struck.
Mike,
It certinaly doesnt hold 38psi to the limiter, is simply uses that for a midrange shove!
On position 12 for today I had mapped it at 40psi peak, 34psi held.
When the HG failed, I'd guess at position 7 it was running around 30 psi held.
Old 07-12-2004, 01:53 PM
  #49
A10 COS
A10 COS's Avatar
A10 COS (RS500) has just done 175mph
Old 07-12-2004, 01:58 PM
  #50
JRST
JRST's Avatar
Old 07-12-2004, 02:00 PM
  #51
A10 COS
A10 COS's Avatar
apparently they are all struggling for grip on the start which is why the speeds are low.
prob the same as yesterday too for the rst
Old 07-12-2004, 02:01 PM
  #52
Coldo
Coldo's Avatar
Nice one
Old 07-12-2004, 02:03 PM
  #53
ImaRacing 700
Karl like the Cometic head gasket requires very careful installation to avoid blows,the long studs and outer 4 stretch bolts need special tensions!.....IMO of course......YB's are fooking wanky when tuned anyway
Old 07-12-2004, 02:07 PM
  #54
Mike Rainbird
Caraholic
Ian,
You go outside the compressor map's efficiencies and you WILL lose power, irrespective of what you want to think. There is a lot more to it than just ACTs. I think I can feel a post brewing from Stu to explain this in depth .
Old 07-12-2004, 02:15 PM
  #55
Karl
Norris Motorsport
Karl's Avatar
LOL @ Mike,
Thanks for clearing that up Mike, I shall explain to Nutter that from now on we must consult with your good self on allowed boost levels.
Old 07-12-2004, 02:17 PM
  #56
Ian2wdsaffcos
LMAO @ Karl
Old 07-12-2004, 02:23 PM
  #57
Lee @ Fusion
Lee @ Fusion's Avatar
updates ?????????????
GWAAAAAAAAAN ya fookers .
Old 07-12-2004, 02:30 PM
  #58
Mike Rainbird
Caraholic
Karl,
You can run as much boost as you like, but you know as well as I do, that once you push a turbo too hard you get deminishing returns, to the point that you would probably get the same or even more power at a lower pressure .
Old 07-12-2004, 02:32 PM
  #59
Adam_BlackRS
Ex Ford Man
Adam_BlackRS's Avatar
How comes Mike/Karl/Rod/Martin Johnston aren't there ?
Or is this a casual cossie thrash ?
Old 07-12-2004, 02:35 PM
  #60
M7 COS
M7 COS's Avatar
There's hardly anyone there by the sounds of it, and of those that are there 50% have broken things!
Old 07-12-2004, 02:36 PM
  #61
ImaRacing 700
Unfortunately the only casual thing Mike does is Gay sex
Mike for the brief spike of say 40psi in the mid range ACT's are not a factor!!!!Didnt you once say to me that YOUR saff ran 2.5 bar in 3rd
Old 07-12-2004, 02:38 PM
  #62
Jim Galbally
Jim Galbally's Avatar
sounds like a typical brunters shootout to me
  #63
JRST
JRST's Avatar
im sure that magenta cossie only is running about 400bhp.
i think?
Old 07-12-2004, 02:39 PM
  #64
Karl
Norris Motorsport
Karl's Avatar
I believe it was by invitation only, and many of the well known cars were'nt on the list. I'm not sure what the selection criteria was either.
Old 07-12-2004, 02:50 PM
  #65
M7 COS
M7 COS's Avatar
Why don't PassionFord host there own day/weekend?
  #66
RANJ
RANJ's Avatar
how te fook did a sunroof fly off!!!!!!!1 serious shit
rusty roof ???? trim screws undone ?? cud have been lethal if on road
Old 07-12-2004, 02:52 PM
  #67
marco polo
marco polo's Avatar
i think?
the magenta cos is about 400bhp+ with a t34
  #68
dumped
dumped's Avatar
ranj - you aint supposed to do 167 mph on the road
Old 07-12-2004, 02:53 PM
  #69
Mike Rainbird
Caraholic
Phil, your memory is like your comunication skills - shit .
2.5 bar was in 1st gear only (although I could set any boost level in any gear).
Old 07-12-2004, 02:54 PM
  #70
Lee @ Fusion
Niel had probably stuck it in with Blu Tack
Only jokin Niel , if ya read this
  #71
Smit
The 60ft Launch King
Smit's Avatar
RANJ - it happens mate believe me.
took the runners n everything with it when mine decided to get out n walk.
Old 07-12-2004, 02:56 PM
  #72
Gav Diamond
Gav Diamond's Avatar
i think?
If your on about Pete's, Marco its on a T38
Old 07-12-2004, 03:05 PM
  #73
marco polo
marco polo's Avatar
i am
Old 07-12-2004, 03:11 PM
  #74
JRST
JRST's Avatar
any news
Old 07-12-2004, 03:13 PM
  #75
A10 COS
A10 COS's Avatar
A10 COS - 175.9mph
Kaliber cossie - 170mph
thats all i know
Old 07-12-2004, 03:28 PM
  #76
Mike Rainbird
Caraholic
Just goes to show there is more to gettin to the magical 180mph figure than meets the eye .
Old 07-12-2004, 03:29 PM
  #77
ImaRacing 700
Fook off Mike..why would you say 1st gear only It couldnt physically get to 2.5bar in first gear..ROFL ...... PLEASE PHONE HARVEY FIRST BEFORE REPLYING
Old 07-12-2004, 03:31 PM
  #78
A10 COS
A10 COS's Avatar
its about having the bottle to break as late as poss, i know the 500 will do 180, but me and the old man break to early all the time. it is so annoying
Old 07-12-2004, 03:32 PM
  #79
M7 COS
M7 COS's Avatar
Ho Hum!!!!
Old 07-12-2004, 03:33 PM
  #80
TIFF
Chasing Radders
TIFF's Avatar
Grip from the start helps
Quick Reply: News from Brunters Cossie Thrash Today...
