After a year of reliable motoring
The LCr has been replaced with another Cosworth. Been and got one today, its a 65k mint example, with a t38 and greys, a1 rally sport built engine. Been out and taken a few pics tonight....
Will be changing the wheels first, theyre scrubbage city
Looks a tidy thing that
Shame about it being homosexual transmission tho. How long before it breaks or is it uprated??
Wheels should sell no problem Id have thought.
SPEC: Full engine rebuild by Simon @ A1 Rally Sport. 200 block, arp bolts, re-bore, new mahle pistons (standard compression with valve cut outs) NEW group A oil pump, bd14 inlet cam. Group A headgasket, done 1000 miles running in, now covered 6000 miles.
-FULL ENGINE RE-BUILD @A1 RALLYSPORT
-T38 TURBO
-RS500 ALLOY INTERCOOLER
-FORGE ALLOY RAD
-Pro alloy lightweight spal fans
-COLLINS SOLID ENGINE MOUNTS + gearbox mount
-FULL SAMCO HOSE KIT (every hose)
-jus had re-placement gearbox from low mileage escort cosworth
-NEW! AP RACING CLUTCH
-new grey injectors
-Graham Goode mirror image group A breather system.
-full stainless power engineering exhaust system
-fully poly bushed front and rear
-SECS ECU MONITOR (rare as rockin horse....)
-alpine headunit with ipod control
-full koni suspension with -25mm springs
-B&M Quickshift
-Brand new front driveshafts
-Group A fuel pump
-Graham goode swirl pot (not fitted)
-3 BAR MAP SENSOR
-REAR STRUT BRACE
-Group a coil
-Ford Motorsport ht leads
-new alternater
-new battery
-2 new dunlop sp9000
-2 new toyo proxes
All parts listed have been professionally installed over last 2 years. currently running a reliable 21psi approx 360bhp. 30psi would see over 400bhp! currently on escort cosworth alloys, standard alloys also supplied. Fitted with cat 1 alarm/immobiliser with cert for insurance.
Spec taken off the advert of the car
-T38 TURBO
-FORGE ALLOY RAD
-new grey injectors
-B&M Quickshift
-Group A fuel pump
-3 BAR MAP SENSOR
-REAR STRUT BRACE
-Group a coil
-new alternater
-new battery
-2 new toyo proxes
