Missfire Arrgggggg...pls help...
Ive just put my car car back on the road today and it's got a missifre when you nail it. Once it gets to about 4500rpm the rev counter goes off the clock and the exhaust pops and bangs and the car tries to hold back.
On idle the rev counter sometimes jumps a little.
These are the things I have changed over the last few weeks,
Distributer Cap (Genuine Ford)
Rotor arm (Genuine Ford)
Ht Leads (Bosch)
Grp A coil (Woodford Garage)
Spark plugs (Motorcraft pp12's same as what came out)
Phase Sensor (Matt Lewis M, Marrelli)
ECT Sensor (Matt Lewis)
and ive cleaned the crank sensor up.
I did tinker with the boost a little bit, if it over boosts what would happen?
and whats the chances of it being an injector?
Ht Leads (Bosch)
FWD is for small children
Have you set the time correctly ?
Is the coil new ?
I had the same problem once with a Porsche and the problem was with the coil, once I put some Rpm on the car, the coil overheated and the car cuted off....
Regards
Jorge
Is the coil new ?
Regards
Jorge
Chance it for a regular Cossie coil and see if it gets the same missfire...
Also maybe one of the sparks is bad, nevermind if they are new....Last year I've bought 2 sets of Bosch that were defective and were new....Now I only use NGK.
Regards
Jorge
