how easy to put a 2.0 zetec in my mk4 xr3i??
hi,
what do i need and how easy is it to put a 2.0 zetec in my escort? what parts do i need and can i use my 1.6efi clutch and flywheel. help please!!!
you need off the top of my head
zetec 1.8 sump and oil pick up pipe
fiesta mk 3 alternator bracket orcould use 1.8 zetec and get a belt to suit a non p/s model
engine loom and ecu
exhaust manifold and downpipe
cvh engine mount, 1 hole need modding and re welding
you can use your cvh flywheel and clutch, you just need to drill the holes out slightly bigger so the zetec crank bolts go in, i had to do this on mine when i did the conversion
engine loom and ecu
cool, all sounds good, where to i find that thread mate? how easy is it to wire in? do i need the 2.0 loom? which is the best 2.0 to get? and where do i get an exhaust manifold from?? very grateful for the answers to my many questions
JoeyBoyden
04-01-2024 02:36 PM
kyle_st200
Ford Focus Diesel
21-08-2015 09:28 PM
