Ring Gapping Who Knows There Stuff?
right i will be using JE pistons in my focus rs engine. i have all the stuff now and the block has been honed to size by halesowen engines! i have measured the internal bore and i have on cyliner 1 - 86.020 cyliner 2 - 86.010 cylinder 3 - 86.020 cylinder 4 - 86.010 all in mm but im a bit lost with gapping.
the instructions say that for high performance street and strip the top ring should be gapped to bore x .0045" the 2nd ring bore x .0050" and the oil ring min .015"
now for that i am working out the ring gap of the top ring should be 3386.614 (mm converted to thou) x .0045" = 15.239" is this correct? or am i doing something wrong? so in theory the gap should be 0.0381mm? getting muddled in numbers here lol
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
Convert your cylinder bore diameter to inches and then multiply it by the given ring gap suggestion.
For example.
Cylinder 2.
86.010mm converts to 3.386"
Top ring gap calculation:
3.386 x 0.0045 = 0.0015237"
You're looking at 15thou which is about right - if you're going to give it death on the track or hit it with gas later on i'd personally make it a little larger.
Make sure the ring faces are still square to each other when they're closed up too.
For example.
Cylinder 2.
right just checked the top ring gaps and from that conversion above they should be a gap of 0.0015 they are 0.0090 so whats wrong there then? these are the rinds supplyed with the je pistons they are je rings these jobbies
0.0075 oversize on the gap seems a bit much
i have mate and the gap once i have done that is 0.009 as said! and from the calculation they have given it needs to be 0.0015 easy tiger lol just after some friendly advice
lol did you use a file or have you got the proper tools? sounds like fun! lol dont mind if it takes a month as long as its done right! its my 1st engine build so i want everything perfect! work in engineering so have all the tools dials and measures to hand only i work in microns at work so smaller tolerances than then engines
Cause if thats inches, then I dont believe for 1 second that the correct gap is 1.5 thou, more like 15 thou!
So I think you have got the decimal point in the wrong place.
will has converted it for me in post #2
For example.
Cylinder 2.
i have checked the gap and i have currently got 0.0090" on the top rings
Just checked, Will through an extra zero in there somehow. 3.386 x 0.0045 = 0.0152 = 15.2 thou.
So i'd use a 16 thou ring gap if your not going NOS or huge boost. You need to file about 7 thou off the ring.
top stuff thankyou mate
sounding a bit better! going to be using upto 2 bar of boost mate looking at 450 - 500hp
got 3 in! the 2nd rings were fine but the top ring needed the 7 thou taking off! started with a file and it just wasn't happening! so i had a new oil stone with course and fine side! took the material off with the course side it came off quite easy
so was chuffed about that had them gaped in about a hour! and took me about 3 hours in total! put them in all nice and lubed up and positioned them to spec and put them in! nice its looking more like an engine now
thankyou for your help all that did
Im using this tread because i have the same quest
Building a new engine zetec turbo, with new pistons and new rings do you use the tolerance that is in the haynes book for the gap on the pistonsrings??
Haynes doesnt cover zetec turbo, you need to ask your piston manufacturer what they recomend if you are using forged pistons, if you are using standard pistons then add a few thou to the standard clearances quoted.
its forged pistons from supertech, ok so i need to contact them.....
Yes mate you should, although supertech are just vendors I believe so they might need to refer to the manufacturer.
You should also be asking them for PISTON TO BORE clearance as well as the ring gaps, as that will be larger than standard too. 3-4 thou or so is typical for a lot of aftermarket forged turbo pistons IME, which is double what most standard cast pistons are.
You use a vernier caliper to set to the same size as the piston.
Then you use that to set a dial guage to zero.
Then you place the dial gauge in the bore and it measures the clearance.
Just ask your machine shop to do it when they bore it mate, thats your best bet probably if you havent done it before.
Lol @ tiny
Lol @ tiny
deathrider666
Sep 28, 2015 06:12 PM
