mt75 viscous coupling modification help?????
Old Apr 29, 2009 | 02:11 PM
evansluke's Avatar
evansluke
Default mt75 viscous coupling modification help?????
I am looking at using a mt75 for a project.
From my understanding the box provides a torque split of 34% front and 66% rear. i was wondering if it is possible to modify the mt75 gearbox so that the output from the transfer box, which usually drives the front wheels could be made to provide the 66% proportion opposed to the rear wheel drive shaft output.
therefor in theory giving a 66% front and 34% rear bias.
if possible what would need to be done.
cheers
Old Apr 29, 2009 | 03:12 PM
evansluke's Avatar
evansluke
Or maybe if simpler make the split 50:50?
Old Apr 29, 2009 | 03:15 PM
zvhrst's Avatar
zvhrst
why would you want more to the front?
i have no idea about doing what u want, but i can tell u how to do a MT75 hybrid for RWD only
Old Apr 29, 2009 | 06:26 PM
evansluke's Avatar
evansluke
Basically i am looking at using an mt75 gearbox in a mid engine 4wd layout. the gearbox will then be turned around and facing the opposite way.
so now the output that used to drive the rear wheels will drive the front!
to solve the problem of effectivly having 5 reverse gears and one forward gear the differentials will be turned over!!
Old Apr 29, 2009 | 06:27 PM
evansluke's Avatar
evansluke
i already know how to make the mt75 hybrid! this is not what im after!
Old Apr 29, 2009 | 06:32 PM
kjc300's Avatar
kjc300
Some of the rally guys have 50:50 split, or know about them. Er, try markk on here?
Old Apr 29, 2009 | 09:36 PM
Psycho Warren's Avatar
Psycho Warren
Carbon Crazy
you making an RS200 replica?? if so just use the porsche transaxle or renault UN1 (for low power) and live with RWD.
Old Apr 29, 2009 | 10:33 PM
markk's Avatar
markk
you can buy a centre diff unit that gives you 50:50 split, the way to twll the differances is that the annulus (iirc) has four sun gears in it instead of the std three, also beware of turning diffs over, as the pinion bearings have oil guides in the lower sections of the diff, if you turn it upside down, it then has no oil supply
Old Apr 29, 2009 | 10:44 PM
andrewg's Avatar
andrewg
i sold bara a 50;50 split not long ago
Old Apr 30, 2009 | 05:26 PM
evansluke's Avatar
evansluke
How much are the centre 50:50 split diffs and who am i best speeking too about them?
cheers for all the help!!!
Old Apr 30, 2009 | 05:52 PM
ybturbo's Avatar
ybturbo
Are you sure that the chain on the transfer box will be ok?
mjonathan24
Oct 29, 2015 10:39 PM
gingeRS
17
Oct 2, 2015 09:42 AM
Iain Mac
Sep 30, 2015 09:39 PM
deathrider666
Sep 28, 2015 06:12 PM
