Anyone used Wynn's Engine flush before?
#41
just finding my feet
hell the staff pay cost PLUS 17.5%,,,,, no customer gets it cheeper than staff rate !!!
#42
That's Crazy !!!
It´s only to be used ocasionally, I only use it once I buy the cars to clean the engine !
If used frequently in will damage the seals, because it's a agressive product !
You will get the same result on your motor seals, as if you use agressive flushing radiator fluids all the time on your radiator....What a bunch of Idiot Mother F***....
OIL FLUSH DOES NOT DAMAGE OIL SEALS !!!,,,, IT DOES NOT,,,, IT WONT AS ITS DESIGNED NOT TOO !!!!
its the older engines with the gunk around the old seals HIDING the leaking seals problem,,,, use the oil flush and the oil stem seals covered in crap have it removed,,,, and then the engine either smokes or just seems to burn oil
this is why its not to be used on cars of high milage UNLESS they REGULARLY use engine flush !!!
it gives the product a bad name,,,, people blame the product for fucking there engine when in reality the engine was fucked but you was not aware of it
#43
Resident Wrestling Legend
mate your the one whos got it wrong
#44
#46
I've always used WYNNS engine flush, just taken my 200,973 mile cossie engine apart, the crank is on STD size on both big ends and mains, the 200K mile old thrust washers give 4 thou so still perfect, compressions were ace emissions 0.97% co(NO closed loop) ace mpg, but bore/rings were shagged only just got it with 1st oversize, nearly had too much wear for 1st, cams ok etc, new oil pump fitted(Ł24).
I use flush on every oil change I run it around for a few hundred miles first, the last 20,000 miles were done on comma mineral oil 20W50 due to the rate of burning it!!
#47
#49
I used wynns engine flush on my 55000 mile st200. Oil was black as fook! 2000miles later and the oil is still clean! Also used it on my 105k mondy diesel, no issues!
Although I have been recommended Forte stuff, thats what the good garage scheme garages use.
#50
Oh, I didn't see the above post....
What the f****, I am well off the discount then.
I got a Millers engine flush and the guys sold it to me said no problems with seals etc. Shit can happen only if use some advanced stuff made for racing cars or something like this.
Thanks guys
Thanks guys
