brake bias valve on cossie
Ive had enough of my cossie rear brake reducing valve leaking
so is it a good idea to remove it and put in a adj bias valve?
i pressume it will do the same job-i can get it on a brake roller tester to get the right setting etc-anyone no any different?
cheers
cheers
I got sick of the adj valves on my RS turbo, so went to a bias valve. You will need to repipe it to a front/rear split rather than the diagonal as std.
Red_bull
09-08-2015 08:34 AM
