need a hole cutter that actually cuts through metal?
where from? dont want to pay a lot as i only need to cut 1 hole ![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
52.4mm to fit a guage. metal is 1mm thick steel.
unless anyone in swindon has one i could borrow?
last time i tried to cut a hole in metal it was the bonnet for the aerocatches, the peices of crap didnt even go through!
its a 2 inch hole saw you need. try not to use huge speed when cutting through and try to use cutting fluid. hole saws heat up and burn out very easily
a wood one would proberbly work on 1mm steel, do it nice and slow, make sure its flat on some wood and keep spraying wd40 on it as you're drilling it, should be fine
http://auto.frost.co.uk/search?w=52mm+hole+punch
They're the ones I bought, pretty sure you can get the 52mm seperately though.
No contest, hole punch it is, no mess no swarf, just a little manual labour, holes are so perfect don't even need deburring afterwards.
I have the whole set of punches that do from around 1/4" up to 4 1/2", plus metric, best things I ever bought for this.
Hey up Dan, long time no spekken ![Big Grin](https://passionford.com/forum/images/smilies/icon_biggrin.gif)
Cant you mark out the area to be cut, then use normal small drill bits to go round the outside till youve gone all way round, then metal file to make it as smooth as it needs to be?
Thats how I'd do it
Thats how I'd do it
Bloody hell....that's a long winded way of doin it mate lol! Stop fuckin about and get it done fudge, i've probably got a holesaw that'd do that, give it a quick go with the file after and it should be fine. You goin up combe tomoro?
Fudgey, you get it sorted?
a couple of years ago i needed an alloy piece cut/modified, i took it to a metal cutting company who make scaffolding etc.
they are located in Old Walcot, next to sussex square.
cheers dave, ill let you know when
nice one bud, pisser about the amal valve lol
no in any rush at the mo, will be working on the car all day tomoz to finish off the brakes etc, not sure yet how im going to bleed them if i cant find the right size cap for my pressure bleeder lol.
also got to roughly set the compression struts and tcas so the thing goes in a straightish line lol, do a complete nut and bolt check to make sure its not going to fall apart while being dragged down the road and put some oil in the gearbox and diff...
oh and fit the drivers seat and steering wheel
and whatever else i find...
Mark RS
12-10-2015 06:01 AM
07-10-2015 12:56 PM
